-5V Rail
mremulator
1CR
OK, I'm trying to get the sound working on my Chase HQ board, however I ordered a JAMMA PSU without the required -5V rail. Until the replacement comes, is there any way to get -5V? What would happen If I used the +5V rail or used an ATX PSU or something?
cheers
4,058CR
If you use the +5v something will go pop and be damaged. Wait until a PSU with -5v arrives.
I believe you can use an ATX PSU but I've never done so and therefore can't comment.
virtvic
The Cabaret King
21 (96%)
2,012CR
You can get a device that turns +5v into -5v, but it would be easier, cheaper (and better) to get a proper psu with both on.
Just like Guddler says.
obcd
3,830CR
The older dynamic ram chips needed -5V to operate properly.
An ATX power supply has a -5V rail. You should be sure it can deliver enough current.
An ATx supply has a "power on" line to switch it on. It also has a "power good" input that makes it turn off if the supply voltages are not within range. I have seen designs that had the "power on" permanently connected to ground to leave the supply in switched on condition. You will need some load on the +5V and +12V as otherwise the +12V and likely the -5V as well will be 2 low.
Equites
Chief Sheesher®
35 (100%)
3,329CR
Yes you can convert the +5v to -5v using something called Negatron, sounds like a Transformer I know.
Mark (retroclinic) uses these.
Got to agree with Martin, a proper PSU is the solution.Equites2014-10-19 14:04:40
RGP
Meeter & Greeter
2,039CR
Yep, you can bung a negatron in there it inverts the DC line in an isolated fashion (omit long winded physics bit), however, you will get a small amount of voltage drop so if your input line was exactly +5v you will likely get about -4.89v or something like that as, just like a diode or other component, it requires some voltage/current to perform its task.
You can use an ATX PSU as mentioned with the PWRON line (pin 14 usually) connected to GND, most ATX's i've seen recently will give 0.8a on the -5v line which given a lot of SMPSU's are only rated at 1.0A for the -5v generally you would be ok (take this lightly and confirm it rather than accept it by measuring the current).
Side note: i'm running our main strip of LEDs in the unit off an ATX's +12v which delivers 38A, I measured it not pulling anything more than 20A in total and that's 6 strips with RGB amplifiers plugged into it too. The +5v rail is happy with no load as i've left alone the PWRGOOD line to activate it so i'm simply pulling +12v which would be used for motors and fans anyway.
Personally i'd wait for the correct PSU to turn up though - safer, easier to understand, no fiddling and designed to fit in the machine.
