6 button jamma
Jenksie
1CR
Hi all
I'm buying a cab that comes with a 6 button jamma. Is there any way of converting this to a regular harness and kick harness or is it a case of ripping out and starting again?
phillv85
490CR
It's nice and easy, just remove the connections on buttons 4-6 that are currently in place and connect your kick harness to them, the other end of the harness will go straight into the board you're playing and completely bypasses the JAMMA connector.
Jenksie
1CR
Thanks. Does this cause an issue with grounding as there won't be a ground on pin 27. I'm thinking about starting with connecting to a jpac and so was worried about the grounding with that.
phillv85
490CR
No problem, we all have to start somewhere
