6 way Jamma Switcher problems
jerryspaghetti
38 (100%)
1,998CR
Hey guys,
Picked up a 6-1 jamma switcher and it's not working as it should.
Works perfect with no boards in and cycles through the 6 slots.
With boards in though it's not cycling freely.
I've tried putting them in in different combinations and got the first 4 working ok but when i added a 5th it wouldn't cycle to that slot in sequence.
I tried adjusting the voltage from the PSU and it helped a little at first but still wasn't perfect but now it's just relaying back to slot 1 everytime.
I'm going to try installing a suzo happ switching PSU i have and see if that helps but anyone else had this sort of problem?
RaveN
1,325CR
I'm assuming it has 3 relays for each board (12v,5v and -5v) and has all the grounds shared?
My best guess would be that a board is pulling enough current from the 5v to very briefly lower the 5v causing the controller (assuming it's a PIC/Atmega or similar) to brownout and reset?
Do the relays have functioning flyback diodes to protect the controller, and does the controllercpu have suitable bypass caps (e.g something like 0.1uF ceramic and 1-10uF electrolytic) on the power pins?
BulkSlash
81CR
I’ve got one of these and I could never get it to work with any of my PCBs in any combination. I think the best I managed was getting it to boot the first board but it would crap out as soon as I tried to change to another game.
I gave up in the end, but I’ve still got it somewhere so assuming your model is the same as mine I’d be interested to know how you get on. I remember thinking it was power related but the voltages all looked good at the test points on the switcher.
jerryspaghetti
38 (100%)
1,998CR
Hey thanks for the reply, it’s a riddled tv switcher.
It has 12v, 5v and -5v though I’m not sure if that’s on each separate slot though.
It does seem to be resetting to the 1st slot although it’s a bit intermittent.
