60 in 1 update?
Rich_UK
4CR
Hopefully I’ve put this in the right section, anyway.. I recently bought a cocktail with a 60 in 1 icade but have since discovered a few problems, a couple of examples are; 1. when playing Moon Cresta there’s no sound when firing, all the other sounds are there just there’s no sound when you fire, 2. Donkey Kong only appears to have 2 levels, it goes from level one to what I assume is the final level, and then back to level one. Can these boards be updated?Rich_UK2019-12-29 16:29:23
Lurch666
21 (100%)
4,518CR
With donkey kong it's probably the American version that does the levels in a different order.
It's something like girders,rivets,girders again then lifts then girders then rivets and so on....
Mr20to5
1,366CR
Hi.
So the sound on these boards are notoriously bad. Your Moon Cresta may simply be due to the poor emulation.
As for DK. Do you mean screens or levels? Nor wanting to teach egg sucking, but are you aware of the screen progression in the game?
Girders, Rivets = level 1.
Return to girders, then springs, etc. = level 2.
Return to girders, etc, etc.
Rich_UK
4CR
Ah I see, I’ve only got as far as girders, rivets, the girders again, not got past the second girders yet as I still suck as bad as I did back in the day. Thanks for the info.
Mr20to5
1,366CR
They are all of a muchness. To be fair the gameplay emulation on the 60 is ok, it's the sounds that suffer.
But they are all poor compared to the real pcb. You get what you pay for.
If you want emulation then you could go for a rpi2jamma (depending on what era/type of game you want - won't do polygons), but is relatively cheap and doesn't need separate power source. or a full groovymame pc set up
- accurate emulation, more expensive and needs separate power source.
big10p
Coins detected in pocket!
6,093CR
The missing sounds are due to these things using a very old version of MAME that used sound samples for quite a lot of sounds that hadn't been emulated yet. For some reason these boards can't play the samples, or - more likely - they just didn't bother with them. My PB6 is the same. I added Berzerk to it but it plays with no sound, even though I tried to include the needed samples.
I seem to remember the jump sound is missing from DK on the 60-in-1, too.
[edit] actually, now I seem to recall it was the walking sound, not the jump.
big10p2019-12-29 18:13:15
Rich_UK
4CR
The walking sound is there on mine, and jump.Rich_UK2019-12-29 18:22:23
penrhos
747CR
The Game Elf Vertical is much better than the 60-in-1 and it should be a straight swap-over for the 60-in-1 PCB.
Elf has Space Firebird on so it's the vertical-multi PCB I use in my Vert cab.
Sound emulation and frame rates on some games still suck though and make sure you get the latest version with the most games on.
If you have the skills and the cash then an RPI and JAMMA converter are a better bet for accuracy.
penrhos2019-12-29 18:31:56
big10p
6,093CR
Ah, must be on the Pandora's Box, then. Been a long while since I had a 60-in-1.
Rich_UK
4CR
It’s all new to me as it’s been a long time since I’ve had a little space for one or two machines, the last machine I had was an Operation Wolf, which I sold (when I moved and couldn’t get it through the door at the new place) for £50 in great condition and perfect working order
none of these ?? in 1 existed back then.
tb2000
3,584CR
I think you can get rid of some of the sound distortion by using an amplified pair of speakers through the socket on the pcb. I seem to remember the original early 60-in-1's having two eproms on them which maybe could be re-written but the later ones are all on surface mounted stuff.
Rich_UK
4CR
I think I’ll just switch it to an elf and see how I get on, I’ve noticed on eBay they’re £55ish from China or over £100 from the UK, is there any difference apart from the 3 week wait?
penrhos
747CR
None - just make sure you get the vertical version.
If you shop around you can get a horizontal SD card at the same time as the Vertical Elf (they are encrypted with the PCB serial number) for about £20 extra.
Rich_UK
4CR
Perfect I’ll get one from China, not sure there’s any horizontal games I’m really fussed about, I just love all the late 70s early 80s classics from my youth, if I can get this playing a few of ,y favourites properly I’ll be happy. Then the next quest is one original upright machine from the same era, not sure which one I want but there’s more than a few I’d be happy to get. More than anything I’d love a sit down driver but sadly my house is way too small.
