68000 CPU Red Hot !!
TheDaddy
14 (93%)
7,230CR
Hey guys , Got a 68000 cpu thats getting red hot straight away. Not had this before, I have tested and board seems ok CPU 5v -0v not shorted. Unsure if there is anything else that can cause this bar a bad CPU.
I have lots of work to do on the board, Going to be a long I think !
Thought I would ask before I start ripping stuff off.
Thanks in advance :)
Dave.
P.S Going to be Saturday before I can do anymore testing now though.
Flinnster
The Dino King
29 (100%)
2,566CR
Clock rate would be my thought.... see what the crystal is.
Dunno if there were differently rated 68000's like there were Z80A's and B's etc..
Flinnster2021-06-14 23:07:51
5,415CR
Don't know much on this stuff, interesting thought on it though, pretty sure there are different speed 68000's like in Amiga are 8mhz, Thought I'd seen some at 12mhz and ones in Outrun are 12.5mhz
I mentioned else where earlier about games like Chase HQ on Amiga seems slow compared to Arcade, is that why?
TheDaddy
14 (93%)
7,230CR
Yeh i need check the clock, will remove clock and see if it still gets hots , cheers flinnster.. Yes chris clock speed to the 68000 makes a difference. Some CPS1 A boards have different speeds causing games to run slow. Cant remember games and speeds off top of my head think its 10mhz and 12mhz on later ones.
Not sure if this is the issue with Amiga though.
Dave.TheDaddy2021-06-14 23:50:30
5,332CR
How does a 68000 cope if lots of the address pins are shorted to 5V or ground? (Do the address lines measure sensibly with a multimeter)
Regarding games and CPU speeds, the 50/60Hz vsync is the main source of a timing in games. So a faster CPU can just move more stuff around in each frame or have more frames - the play speed should be the same if coded right (although maybe at 5fps or something ugly). Chase HQ is a triple CPU, hardware accelerated monster of a system, so it was remarkable to get so many half decent home versions. X68000 is a surprisingly iffy version for a change.
5,415CR
That's what I wondered, should be able to make the game run how they want I guess with good programming. Maybe they were just at the Limit of the hardware cramming as much in as poss and they don't have seperate CPU for Audio like Arcade Boards, they didn't seem slow in the day but then I didn't have them all to play at home and compare so quickly
Some of the old PC games Vary speeds due to CPU, Alone in the Dark was fine on 486 systems, when you played it on Pentium 1 or 2 etc the game still plays same speed but the infrogrames logo at start spins round faster on later PC's so it's not locked I assume and will run at what speed cpu is, when you kill them and the spheres go up that's also faster, Theme Park you couldn't play as it was like you have set on 50x speed which was amusing but unable to play it anymore
Double Dragon is classic example of programming
I bought that rubbish when it came out on Atari ST, loved the Arcade so much but not quite the same is it, had Amiga after and same on that, everything about it was poor, graphics, sound, game play, then someone does Double Dragon, it was pretty much same game with different baddies, bosses and backdrops, yet that was a well polished conversion that was very close to Arcade, just think why couldn't they manage it on the original
Bods2021-06-15 07:33:33
