6840 Timer Chip
jonhughes
1,156CR
Hi everyone,
I'm receiving an error from An MPU4 Video board. It displays the message: 6840 Timer Chip. This appears to be a Motorola MC68A40P chip on the board. Can this chip be a direct swap or does it need to be programmed first and then replaced?
Its description is a programmable timer module, indicating some programing is required. I not fully clued up on chip operation.
Any help, greatly appreciated.
Muppz
362CR
Its just a bog standard support chip, no programming is necessary.
Programmable only in as much as it has registers inside where you set the timer parameters and this is done by the processor on the board.
jonhughes
1,156CR
Thanks very much.
They are available in the States. I just hope it is that chip and nothing relating to that chip.
I have another board that is indicating faulty RAM. The RAM is socketed - swap out all the RAM and the RAM error is still there.
Muppz
362CR
afraid I'm not familiar with those boards but it sound like you have a dead buffer or chip select between the cpu and the ram chip.
I might have a 6840 knocking around here, I'll take a look later on.
jonhughes
1,156CR
I've ordered one from the states, but if you have one that you no longer have any use for I'd be happy to pay for it as a spare. The CPU is the same as used on Sega boards, can't remember without taking it out. If I take some photos of the board maybe you could ID some chips for me? It's hard to work on this board since it has to be installed in the cabinet to get it functioning with the ROM board in place.
