ABI DIT-24XP cable.
cliff_poole
1,069CR
Could anyone that owns one of these please upload a closeup of your test cable ?.
Ages ago, Macro kindly posted the pinouts for me. I have made a cable and buzzed it out to the test clip to confirm all the connections are OK, but I just get "No Supply", on the screen when I try a test. There is power to the board and I can test chips out of circuit OK.
I'm wondering if my pin 1s are the right way around.
Macro
2,009CR
are you powering the board from the ABI ?
to use the tester in circuit you usually have to short out the crystal (so the board cannot interfere too much) and then connect the red and black banana sockets on the ABI to 5v and GND on the board to be tested.
I find that quite good since it means you can test chips on the bottom board of a stack of boards which is a right PITA to do normally!
cliff_poole
1,069CR
Ah OK, thanks !, no I wasn't powering the board from the ABI. Should have read the manual
. Packing in for now but I'll give that a go tomorrow.
The other stupid mistake I made was getting the connectors on the clip end the wrong way around so I can't open the clip wide enough to get it on the chip. That is a problem for another day though.
Mesmeric_G2013-10-05 20:01:33
cliff_poole
1,069CR
I am now powering the board from the ABI's supply and it is telling me "No Supply", so I still think I have got the cable wrong somehow.
If I am facing the ABI, is pin 1 of the 50 pin connector on my right ?.
