Adding headphone socket and power switch to cab
deanzor
139CR
Hi guys.
Have any of you fitted a headphone jack to a cabinet? Now my Dino King is in the living room, I'm thinking I should make it so it and the TV can co-exist. I'd like to have a switch as well, so I can switch between headphones and speaker as and when. Asking here as no doubt someone's done this in a smarter/cleaner way than I'd manage winging it from scratch
Also: is there a go-to solution for fitting an easily accessible power switch to cabs?
Interested to hear peoples' thoughts.
Dean
5,332CR
JAMMA is mono, so take the speaker ‘-‘ to the headphone jack ground and the speaker + to the L and R of the headphone jack.
Maybe put a 100 ohm variable resistor in-line to allow volume adjustment other than he game PCB.
For the switch, to make it easy, keep the headphones wired-in permanently and just put a switch on a wire to the cab speakers.
Mains rocker-switches are readily available, it’s where you put them that needs the thought, aesthetics wise.
Just some thoughts - never tried it, so could’ve missed something (await a second opinion).
philmurr
48 (100%)
2,378CR
As JB says.
But also you could use a mono socket which should also have a "normally closed" connector that opens when you plug in the headphones. Wire the speaker to the normally closed connector and the + to the audio in (and - to the GND connector).
When you plug the headphones in they will disconnect the speaker and pass the audio to the headphones.
deanzor
139CR
I'm wondering if I can make it reversible by taking off either the card slot or the blanking plate next to it and have a credits button, headphone jack and maybe a power switch all on there.
Flinnster
The Dino King
29 (100%)
2,566CR
Yeah I've used switching headphone sockets in the past, so I'm planning on using those on my pi setups to allow headphones to be plugged in which will automatically silence the speaker output from the board.
Wiring up a headphone from jamma would be very similar. Just wire both headphone sides (L+R) to the jamma speaker+ pin, and the headphone gnd to speaker- pin. You will likely need resistors to bring amplified audio down to headphone volume level though. Even better put a pot in between speaker+ pin and where you join L+R speakers for the headphones.
I've not yet put a headphone socket on the cab itself however. There is a flat space under the control panel, just in front of the front door when closed that would work well and be nice and hidden. It would involve drilling into the plastic surround however.
For now I've not bothered because there is a 2mm gap above the closed dino king door where a flat headphone extension cable can easily be sneaked out.
If you have taken off your security bar, you have 3 holes on the lower right hand side of the cab where you could also easily mount a 3.5mm headphone socket.
Flinnster2018-09-17 13:17:07
grobda
1,061CR
might work, i can see problems for two resons;
the output of a pcb is preamplified to drive a speaker, and will be too loud over headphones unless turned right down, but you'll proabalby still get all the hum, making listening unpleasant. YMMv depending on the PCB.
wiring any resistors in series with the output will affect the impedance; PCB amps are generally designed to drive 8 ohms. changing this by wiring two speakers in series or adding a volume pot will affect the sound quality and possibly (dont really know for sure) make the amp unhappy. the only cabs i know that use resistors post amplification are atari vector cabs which use a low value wirewound pot.
ofc i could be completely wrong. if i were doing it i'd be keeping a eye (well, finger) on the amp while testing to make sure it doesnt start overheating.
guess you can just try it.
t-m
333CR
You could get one of those speaker to line level adaptors that are used in car audio, you could use that to drive a headphone amp.
Venom
820CR
deanzor said:
Hi guys.
Dean
Just turn TV sound off and wife can read the subtitles !
deanzor
139CR
Fair point on the Jamma kicking out amplified sound, had not considered that.
Even getting just the Pi switchable through headphones would be a win tbh. Will try it the Flynn way, thanks fellas
