Adding speakers to audio circuit??
G
Guests
Guest
So... I have these sitting around now...
I have an idea...
these have some rather nice speakers in them and are actually really comfy... I'm thinking of making up a base for them so i can use them with my upright cab and also wiring up the speakers via a removable wire/socket so i can have some better sound too.
Question I have is... Would adding another pair of speakers to the audio circuit cause any problems? I have a basic understanding of speakers and I'm fairly sure if you add another pair of say 8 ohm speakers to a circuit with a pair of 8 ohm speakers already it will lower the resistance and put more strain on the amp in this case being a rather expensive Namco I/O board which i would really rather not kill off...
Would adding the ones in this seat cause any problems do you think?
If it doesn't... could be a good use of one of these seats and also a great enhancement to the in game audio. I know the Deluxe sit down Ridge Racer cabs had speakers in the seats and in the frame like i plan to do and use the same I/O board as does the Rave Racer cab so i might be able to get away with it unless the deluxe I/O boards can handle more speakers. Perhaps those I/O boards can handle more speakers? (I have a Rave Racer I/O board spare so this isn't a problem).
Any idea's/information on this please, anyone?
RGP
Meeter & Greeter
2,039CR
In smaller audio amplifier circuits its generally not a problem to add one extra set of speakers.
In bigger "PA" type systems probably not that great an idea to exceed the amplifiers specified delivery efficiency.
What you'd need to know though is what's the amp already doing?
I don't know if a Ridge Racer is a stereo amp off the top of my head, if it is, then adding one more to the left and one more to the right shouldn't be a problem.
If the existing speakers are 8ohm each then you'll be making a load of 4ohms per channel (parallel reduces resistance - someone else can quote ohm's law).
On these sort of 4-8watt amp chips in most arcade games that shouldn't be an issue, you might find the overall output volume lowers because the chip isn't designed for it and it might get warmer at higher volumes.
If you know what chip is being used for the amplifier then you can look the datasheet up, mostly you'll find they work between 4-8ohms load. If it says minimum 6ohms you'll still just about get away but don't whack the volume up to the top.
I'm going off general audio circuit principles here, someone with more knowledge of the specific game might be able to shed more precise info.
G
Guests
Guest
Great post, thank you!
As for what the amp is doing already... It is running 2 speakers in stereo.
I'm fairly sure they didn't specify what Ohm they were running at nor wattage on the speakers. But yeah, that's what it is currently running. The speakers actually have 4 terminals on them so i should be able to wire my other speakers to those terminals and keep it nice and clean with no cutting to the original loom. I presume that will work fine and be the same as splitting a cable?
As for what chip is used. here are some high res images of a Rave Racer I/O PCB I'm not too sure what chip it would be...
https://postimg.org/image/jyn1qnzov/
https://postimg.org/image/vc9l1va7j/
G
Guests
Guest
Yeah the deluxe sit down models had 4 speakers as standard. Mine is an upright and although it has 2 speakers I'm 99% sure it shares the same I/O board so should be able to take the same amount. I'd imagine that's why my speakers have 4 terminals as they are likely the same as the ones used in the deluxe cabs.
Good stuff, time to get busy! Thanks for your help RGB.
