Address line help
bones
1,628CR
Hi,noob to digital scopes. I have a PCB where the Z80 address lines go to a bunch of 4 74ls08's inputs. All the secondary inputs are tied to logic HI. I've been playing with this scope and found that all the signals on the outputs of the 08's match the signal from the Z80 inputs except one. Now if I pop this output leg out of circuit it then matches it's input. This is a faulty PCB but does this mean I have a problem on this address line somewhere else on the PCB that's messing with it or is this observation only occuring because the rest of the outputs are not being affected because the PCB isn't fully booting.
Any pointers appreciated
Andy
bones
1,628CR
Yeah got the schematics, it's a cosmic alien. Trying to understand the diagram lol, It went to 6 eproms and 4 other places that I've just found. I removed all the eproms and the other 3 08's lost their signals but the one I'm concerned with was still active and the signal was still wafty. So I'm assuming that the eproms are ok as they also read ok. I'm going to check the other 4 destinations and check the traces if I can follow them.
Would I be right in assuming that I'm only concerned with the A3 line as opposed to AD3 which I've noticed elsewhere on the schematics. Not sure about the data lines they appear as just D originally then DA,DB,DC,DE,DF and DG appear throughout the drawing, are these relative to the original Data line.
bones
1,628CR
ColinD said:
Either the 08 is weak or something is pulling the line low further down stream, check for bent pins etc.
Thanks, I have replaced the 08 with a known good one. I must say that when I was probing about here a there with a digital logic probe I noticed a lot of floaty inputs and outputs hanging around the 2.4v region, I changed a couple of chips but nothing changed so maybe there is something bringing them down. Again I wasn't sure because of it not fully booting.
bones
1,628CR
Lurch666 said:
Is the address line that's not changing a high address line?
It may be static because the higher memory isn't being accessed.
Hi, I'm not sure if anything is active really, I've got bars of colour on the screen,the star field appears ok and there's a few bits of sprites that appear sometimes flashing in one place then another and back again but that's stopped since I changed a ls00 and the screen shows a static image. All I've done is check the signals from the Z80 address lines to the 4 ls08's and observed the output signal from the ls08. I just noticed that all but one of the outputs was putting out the same signal as the input and didn't know if that's usual.This is the signal going into all the ls08 the other input is tied Hi
The output that is different is this
but if I pop the output leg out of circuit it looks the same as the first pic like the rest when I scope the leg. I just wondered if this was relevant considering the current state of the PCB. I mean does the Z80 put out a signal on the address line regardless, and bearing in mind the address outputs all look the same(which doesn't sound right) is the Z80 actually running, which is what I don't know. The logic probe showed me that there is activity across the PCB, changing inputs and outputs, but I'm not sure where to go now. Got clock signals too.
Lurch666
21 (100%)
4,507CR
The address lines will go to whatever address the Z80 is trying to access. When you lift the leg you might be throwing the code out of sequence that's causing the Z80 to access higher addresses when the code would normally try to access them because you are leaving the address input from that leg to the 08 floating.
bones
1,628CR
I see, I think. What I've done b4 I went to the pub
was to lift all the destination legs that this output went to as per schematics. That was 5 eproms(p5),a ls04(p1),a ls00 (p4) and 2 ls153(p10 & p6),which are all inputs, so as far as I can see the ls08 pin is now isolated from every other component on the PCB. The trace from the ls08 to these other devices shouldn't have any component on it now. But as soon as I reconnect the ls08's lifted output leg to the now empty trace the signal changes as before. So as it is now surely the the state of this output should not change, ughhh unless there's a short to this trace somewhere. Going to re-check the schematics and if I can't find anything else connecting that I've missed then I'll get some clips & wire and make this circuit off board and see if it changes anything.
Lurch666
21 (100%)
4,507CR
If it's A3 that's inactive then that would be an issue.
I was just pointing out that higher address lines might be inactive because of the code not running correctly but A3 should be active.
Which LS00 did you change? The one at R3?
Edit:Note S3 (LS04) is also connected to A3.
Edit Edit:And H4. And N5.
Lurch6662022-09-21 11:19:31
bones
1,628CR
Yes, the one with the wire linking to R2(p9), when I did this the small piece of sprite that was flashing from one place to another and back again disappeared.
bones
1,628CR
On another point, I'm concerned about the accuracy of the schematics because in this part
it shows p2&p12 linked to p4,which is not the case,this has something to do with the data going to the 4 s201's, but will investigate that later on.
cliff_poole
1,069CR
I feel there must be different revisions of this board. My working board has many factory mod wires, but I have seen them without. From my archive photo, I can't see where they go as they are under the sub PCBs, but I can check if you'd like.
ColinD
6 (86%)
1,367CR
Might be worth while checking that line to 0v with a multi meter. It's possible that you might have a bad input. If the board was working and just failed that could be the problem. If it's been stored, it could well have a bent pin. I'm pretty certain that line is being shorted out.
bones
1,628CR
I've only ever seen them with the extra wires on. I think there's 3 untested ones on ebay and one shows the wiring as mine has,as do the ones on Google images. I bought this many years ago as working but never got round to testing it so it may not have worked. The only difference with mine regarding the modded wiring is that at S4 I have 2 resistors in parallel going to the +5v rail,maybe 2 were used to bring it down to 216ohm as they didn't have the single resistor to hand. Perhaps if you could see what yours does there might be of help
bones
1,628CR
So after isolating all the legs on address line 3 it still has a signal on it ???? Can't see any shorts being caused by solder/bent pins. Further investigation shows that A3 is dead short to A10 ???? Suppose it's time work out how and where, hopefully this is not normal, glad it's after the ls08's meaning the Z80s not showing a short between these addresses.
cliff_poole
1,069CR
Is that the resistor on the PCB directly below S4 ?. Mine is a single 1K.
bones
1,628CR
Yes it is that one, the colour code says that I have a 1k with a 270 ohm in parallel with it. So I'm a bit confused as to why it's reading 216ish ohms, you'd think it would be around 500ohm. I'll lift the legs and check they're both ok if they are then what's the point of them if less resistive to take hmm.
The address line short did turn out to be a tiny solder bridge which is now ok. I could barely make it out even with the magnifier light thing I've got lol.
Does a working PCB still boot without the star field board and sound board connected ?
