Advice on mame machine
elv1s
11CR
Hi all,
Was hoping I could get a bit of advice or be pointed in the right direction.
I had a machine that died a while ago and has been living down rav's unit for a while now , a few weekends ago Rav attempted to fit my new monitor and we think the PC gave up on life , this has made me think its time to get a few one. And this is my question.
Is it possible to get a machine built that has a trackball for missile command crystal castles etc and be able to run daphne and possibly have directional controller for Ikari warriors etc?
I have little to zero tech knowledge so I suppose I am hoping someone could point me in the direction of someone that could build one and tell me if all that is possible.
Many thanks
Will
strykr
1,351CR
elv1s said:
Hi all,
Many thanks
Will
Hi Will,
Its certainly possible to get a mame machine to do all these things, your looking at a bit of cash and some configuring tho!
I have had similar setups in the past, I recommend
A Dual core xp pc, can be picked up for 40-60 ish,
a soft 15khz compatible graphics card if your going into a proper arcade monitor (and you should be
A Jpac for all the standard controls (joystick for daphne and mame etc)
(if your just going vga out to a pac monitor or something, then swap the
jpac for an ipac and dont worry about the soft 15k compatible graphics
card)
A nice mame setup with a front end, Mala is pretty easy to set up if your not big on computers
a trackball and an ultimarc optipac.
an ls30 joystick (or Happ Rotary) for rotary games and an ultimarc rotary interface
and some time and patience!
I can also recommend using mameuifx as opposed to the standard mame build, it has many nicer options and i can confirm it works well with a trackball and rotary controls etc.
Daphne can be a bit of a bugger to set up and you need to "obtain" all the necessary files from the internet.
strykr2013-10-14 22:58:04
