we are all assuming its already 'working' and ready to rewire?
what you need to do is visually trace the wires from the existing board and make a note of where they go to on the cabinet which we assume has 4 way joysticks up down left right and 1 2 or 3 fire type buttons.. credit switch ..power and tv signal etc THIS IS FAIRLY IMPORTANT ELSE YOU COULD CROSS WIRE OR MISS AN ESSENTIAL WIRE FROM THE NEW CONNECTOR .
before detaching the old game note the connections and wire colours .. as you may need it to refit the original board sometime in the future somewhere else? ....number the tabs top and bottom and note which wire came off each tab... IT COULD HELP SOMEONE LIKE YOU TO WIRE A SIMILAR GAME IN FUTURE ALSO . and you will be the 'expert' advisor to another member SLAP FIGHT IS NOT JAMMA WIRED its TAITO unique but SHOULD IF ITS BEEN WORKING, HAVE 4/8 way joysticks already fitted and at least two functioning fire buttons per player (field goal was a rotary control and one serve button wired differently again so may explain the crude but at the time necessary rewiring which you have encountered on the loom and game pcb of the machine)
then FIRSTLY look up the jamma edge pinouts ....on this forum or jammaplus or other internet sites.or machine manuals... identify ground +5v +12v and -5v from the power supply,,, THIS IS CRITICAL and must be identified correctly if in doubt buy a meter and measure what is on any voltage supply wire (that info is also available on forums)
identify the wires to the monitor for red blue green sync(white or yellow) and ground (black)usually those colours?
identify credit and start wires for 1 and 2 players and up down left right of player 1 and for player 2
then when you are fully mapped on paper just unsolder all the edge tabs of the original board leving it clean as possible...... as it could be re-fitted with a female connector if and when reqd ...
using your colour wire mapping notes seek out and re- check wires one at a time stating at one end re-attach wires to your new jamma 28 pin edge plug tabs ...TRIM ANY FRAYING WIRES TIDY so they oly lay on one tab and only have about 6mm of exposed conductor copper from the insulation so they can not touch a near one .........
IF YOU ARE QUITE A PROFICIENT SOLDERER no problem but otherwise ..... i would say hold all the wires up in a bunch and trim them to virtually same length before you start and when they are all attatched the can be bound tidy with a couple of tie wrap pulls ...... many of us on here would also look at applying heat shrink insulator sleeving to each wire too not essential but cheap at maplins cut to just under an inch and thread onto each wire as you go and heat it tight over the tabs to prevent exposure risk once you are happy the wire is on the correct tab ......
its a great confidence buiding exercise to make your own adapters ,,,,,,, as providing you check your mapping and progress slowly and correctly its easy to correct any minor mishaps YOU MAY THINK YOU NEED 3 HANDS BUT NEVER BE TEMPTED TO HOLD THE SOLDER IN YOUR MOUTH AS ITS LEAD TOXIC
carefully as you go all player one wires go on top as does the credit and play 2 on the silverside.. NO WIRES SHOULD BE ALIGNED TO PIN 7 as its the idiot key position supposedly prevents connecting it upside down ,,,,,,, a plastic blank could be obtained or made to insert in the female pin 7 if really desired but not essetial if you always think before attatching a new game .
all the power voltages are at the end between the missing pin 7 and that end ie pins 1 2 3 4 5 & 6 ( 1&2 can be bridged as can 3&4) as you will see these hold the ground and +5 volts respectively and ideally need to be attached across a double tab pad to spread the loading current to more tab area to help prevent overheating of the board edge.
ALWAYS TAKE CARE WHEN FITTING A JAMMA OR OTHER EDGE PLUGS TO ALIGN THE TABS ON THE BOARD WITH THE PLUG PINS SO THEY DONT ACCIDENTALLY CROSS THE GAPS BETWEEN and cause a short circuit...... good luck advice is often on here if you get stuck ?
69er2015-07-01 00:44:19
