Advice with erasing EPROMs
Lee
98CR
I have a cheap and nasty EPROM eraser and I'm struggling to erase any 2716's now I've tried several times at 20 mins a go with several different chips but when I come to do a Blank check they always fail
Is their something I don't know or do I need a better eraser?
ben76
Hunts Spies
1,136CR
I use one of those cheapo ones off ebay..
Never had a problem, I do move the chips round after a bit so the light can get everywhere on them not sure why I just do
You sure the chips are ok?
- Ben
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
actually BEN your right in moving them as some chips especially the 27C4096 by Hitachi have actually got a flaw in them that the window is smaller than the UV erase plate so they wont erase properly unless you move them so that the UV can get inside the chip and erase the parts that are not exposed by the window
Lee
98CR
cmonkey said:
They may be on their last legs.  If so then you'll have trouble erasing them and you may not be able to erase them at all fully.
I must have tried 15 they all can't be on their last legs.
Ben I use the same eraser.are you able to erase 2716's with yours????
Equites
Chief Sheesher®
35 (100%)
3,329CR
What brand of eprom are they? Have you EVER had success in programming them with the eprom programmer?
You sure the problem is the Eraser?
Lee
98CR
Lol no I'm not sure to be honest. The programmer seems to read them ok but then I find a duff one so I stick a few in the eraser for about 20mins then check them with the programmer to see if they are blank and it just comes back as failed.
I tried 4 earlier 2 Fujitsu and 2 intel. None would pass the blank check.
RaveN
1,325CR
Have you read them to see how many 0s are actually remaining (maybe a before and after to see how much of the chip is being erased)?
My lamp is getting on a bit now, so I used to find I would need 30mins sometimes. I remember even balancing a row of chips on an empty fag box to get them closer to the light when a bulb was getting old (obviously not an advisable solution).
What light output is your bulb rated at?
Lee
98CR
I can't find any ratings anywhere on the thing not even on the lamp itself.
I have had it a few years but not used it all that much.
I'll have to take a look at hat you suggested tomorrow and take it from there.
Cheers guys for all your help
ben76
Hunts Spies
1,136CR
Yay for my strange OCD thing
- Ben
sukhbir
46 (100%)
1,733CR
hi,i had a similar problem with programming 2716 eproms,kept erasing then blank check failing.these 2716 require 25 volts to blank and verify check and only 5 volts to read.my cheap programmer programmed most chips and in its device list it stated it could do these,borrowed my mates dataman 48 programmer and it then passed the blank check and programmed with ease.i suspect its your programmer,also you can use tms2516 eproms instead.
cmonkey
1,659CR
You can also use 28c16 EEPROMs an direct replacements for 2716 eproms, much easier to program and erase. Of course that's no good if you want to keep the complete originality of the game board.
Judder
1,009CR
I have the same cheapy eraser as Ben76 and turn it on for 50 minutes and it erases 2716's (and everything else) just fine.
Not sure what programmer you are using, but I have a Willem and a True USB GQ-4X (awesome Eprom programmer) and I can verify and burn 2716's no problems.
If you want I'm happy to swap you a couple of tested blank ones for the ones you have and see how I get on erasing yours?
Lee
98CR
On inspection of the chip after being erased in getting mostly FF, FE, AE, FC, BE etc in no particular pattern
Judder
1,009CR
Sounds like either a duff chip or a problem with your reader from that
Blank should be FF all the way through, and if the chip was reading correctly, but not erased, you should be able to read exactly the same data every time.
Floating data, or data that changes on every read is either a dead chip, bad connection with reader, or faulty reader I would guess.
One thing to try - if your reader is a Willem or similar, press down all of the chips on the board to ensure they have a solid connection with their sockets.
I had a similar problem on mine, and it was caused by a loose connection on one of the reader's own board chips and firmly pushing them all into place fixed it.
simonden
20 (100%)
1,042CR
What programmer are you using? I also have that eraser and it works fine, but for some brands of 2716's (and some 2708's) I get the same problem as you in my Top853.
Works fine in GQ-3X programmer.
