After Burner Help Please
Brettster
1,276CR
I recently picked up a very nice After Burner cab as a project, it was not known what did and didn't work with it but it came with plenty of spares to hopefully make it good.
it came with 3 power boards which 2 looked the same but the 3rd had some of the same parts but had different connectors for the cables.
my first port of call was to see if I could get a working power supply board as most of them looked rusty or damp / broken
so far I've managed to get a good one by swapping parts around and repairing other bits
I've been able to get one of the PCB's tested and it looks to be working ok although it does have some random lines on the screen sometimes
When I first checked the 5 volts I set it to bang on 5V and started from there
I had to turn this up a bit to get the game to boot without constantly looping
it also made the joystick shaker run constantly which gave me a bit of a fright lol
checking in the memory test options It was also listing 2 of the IC's (Ram 125 and 126) as bad but after the bump in voltage the check is now passing all the tests
currently running at around 5.15 Volts which sounds high to me but are these boards hungry?
The monitor in the Cab is bad as the chassis was corroded and when I tried to remove the neck board I necked the tube :( so it's hooked up to a 6" PVM for now until I can find a replacement MTC9000 monitor.
at this point I'm Happy that the PCB is working, as I know these are hard to come by.
But I do have other issues which I where I'm hoping you can help?
I dont seem to have any sound, I dont hear any buzz or whine either so I'm assuming its the Amp at the back of the power board
I've tried all three of the amp's that I have but neither of them see to do anything
I can see the 12V power supply next to it is getting power as the LED lights up and when tested with a meter I get close to 12V
There are lots and lots of wires and connectors in this cab and I've got 4 that dont have anything to plug into them, So I'm not sure if there is something here that's affecting the sound?
these are the 4 connectors
and these are on the back of the coin box
finally the 2nd PCB this came with looks to have had some kind of chip blow out, I've not hooked this up as yet as I'm not sure what that chip does. it's a Sharp PC817 looks to be a photocoupler / opto coupler, input based?
Any help greatly appreciated
Brettster2017-04-22 23:10:40
bbz149
26 (100%)
1,608CR
That looks like an Chip with 4 x Opto-isolator LINK If it is then it would be used to switch Lights or feedback Motor and if a Deluxe Cab also the switching for the Cab Motor movementbbz1492017-04-22 23:13:08
bbz149
26 (100%)
1,608CR
Should be fine! as looks like the internal LED has probably just blown. I'm sure I got some new ones of those I bought for my SHO, ill check tomorrow if I get a chance
dj_yt
787CR
Can you build a quick test harness to run the PCBs in isolation from the rest of the cabinet?
Looks like power and video are fine so you could just connect the audio output to some phono leads and run it through a PC amplified speaker.
Bear in mind the afterburner attract mode only has the occasional sound so you will need to coin up for music.
You should be able to follow the wiring diagram in the manual to figure out what the cables do. The 3 different variants of the upright manual all have different wiring info from memory. It is also normal in Sega cabs to have unused amp connectors in the harness so it's not necessarily a cause for alarm. Also you will find that the size of the plugs varies between machines so sometimes just showing an image of the plug isn't enough, follow the wires back and see where they originate from to determine their purpose.
The voltages for the small PSU that sits near the amp are shown in the UK version of the manual from memory. I recall it had 18v AC input and outputs 12v DC. Check my restore thread as i think i posted the picture there along with some relatively clean shots from inside the cab. You will see below the yellow 2 pin mate n lok connector is also disconnected on mine.
Have you checked the voltage inputs to the audio amp are correct? Those sega audio amps are usually pretty robust.
dj_yt2017-04-23 08:14:57
