After JAMMA-conversion: Problems with game
pc-coholic
1CR
Hi everyone!
I recently got an old cocktail-arcade, an Universal Zero Hour-table, together with three games: Scramble, Moon Shuttle and an unknown game.
The table was delivered without the original Zero-Hour-game and with a custom harness consisting of a DB25 and another 6-pin-connector.
With this harness, I could only play one of the supplied games, Scramble, as the others only display ROM-Errors.
But I was not too happy with this harness, so I decided to replace it with a JAMMA-harness to make things easier in the future.
So I wired everything up (except the coinmech and a few buttons) and connected my Scramble-board to the harness. As this is no Jamma-Board, I started by wiring only the +5V, +12V, GND, RGB, C-Sync and Audio.
Well, it seems, that I made a mistake somewhere along the way... I can hear the test-sound of the board (a contious beep) but the display is just not working correctly.
Normally, at boot-up, the screen should display a white grid on black background for a few seconds, then mute the sound and display the actual game... But now, I only hear the sound and see this broken image...
Has anyone a clue for me, what I could possibly have done wrong?
Or could the fact, that I haven't connected anything but the video- and audio-signal to the PCB, the issue?
Thank you very much for any help!
Best regards,
Martin
pulstar
41 (100%)
459CR
I doubt it isn't working because of just wiring up the video and audio. It should still output this if wired correctly. Because it's not a JAMMA board did you follow the pinouts for the board or for a standard JAMMA connector?
4,058CR
Get rid of that breadboard and do it properly. I tried that once (well over 10 years ago) and it didn't work. Plain and simple. I never bothered to try and work out why but I suspect it's current issues, cross talk on the signals or something like that.
The other thing is that's not a scramble PCB, it's a bootleg Galaxian PCB which therefore requires all the daughter cards that you can see in the picture so it's very easy to knock one of those daughterboards and upset things too.
andrew96
899CR
There is gonna be a lot of volts drop using breadboard!! its a wonder the breadboard has not burnt up yet! i recon the 5v is gonna be just over 4v at the gameboard like that
pc-coholic
1CR
Hi everyone!
Thanks for taking your time to help me here :)
There is gonna be a lot of volts drop using breadboard!! its a wonder the breadboard has not burnt up yet! i recon the 5v is gonna be just over 4v at the gameboard like that LOL
OK - got that :) Trashing the breadboard right away... The breadboard was just supposed to be a test if I got the pinout correctly... (Edit: Just checked: In fact, we are talking about only 3.9V at the PCB
Ah, thanks for pointing out the Galaxian-PCB! I was quite sure, that this was a bootleg, but I couldn't figure out based on what platform... Now this should be quite helpful for checking my pinout.
Martin
pc-coholic2013-11-25 13:46:24
andrew96
899CR
ah 3.9v will likely be your problem, board will not boot with that low voltage, so it will all work if you just omit the breadboard for the ground, +5v and +12v lines, you can still use breadboard for yourtest purposes on all the other lines, just not power lines
pc-coholic
1CR
I just finished soldering "real wires" to the connector and now there is an image and sound - great! Thank you very much, everyone! :)
The game still reboots from time to time and is unplayable after providing a coin and selecting one or two players - but I guess these issues are still just the breadboard interfering ;-)
From what I wrote down before changing the harness, the pinout below should be the correct pinout - but it didn't match any pinout I could find yet for Galaxian-bootlegs. So, just before I start etching a JAMMA-Scramble/Galaxian-adapter: Has anyone seen this pinout yet and can confirm it? (I guess, there are some more buttons I don't have in the pinout, like a second coinmech, a service-button, etc.).
[font="Courier New, Courier, mono"]GND | A | 1 | GND[/font]
[font="Courier New, Courier, mono"]GND | B[/font] | 2 | GND
[font="Courier New, Courier, mono"] | C[/font] | 3 |
[font="Courier New, Courier, mono"]+5V | D[/font] | 4 | +5V
[font="Courier New, Courier, mono"]Coin | E[/font] | 5 |
| F | 6 |
| H | 7 |
[font="Courier New, Courier, mono"]P1 Up | J[/font] | 8 | P1 Down
[font="Courier New, Courier, mono"]P2 Up | K[/font] | 9 | P2 Down
[font="Courier New, Courier, mono"]P1 Start | L[/font] | 10 | P2 Start
[font="Courier New, Courier, mono"]P1 Left | M | 11 | P1 Right[/font]
[font="Courier New, Courier, mono"]P1 Fire | N | 12 | P2 Fire[/font]
[font="Courier New, Courier, mono"]P2 Left | P | 13 | P2 Right[/font]
[font="Courier New, Courier, mono"]P1 Bomb | R | 14 | P2 Bomb[/font]
[font="Courier New, Courier, mono"] | S | 15 |[/font]
[font="Courier New, Courier, mono"]Green | T | 16 | Red[/font]
[font="Courier New, Courier, mono"]SYNC | U | 17 | Blue[/font]
[font="Courier New, Courier, mono"] | V | 18 | Audio[/font]
| W | 19 |
[font="Courier New, Courier, mono"]+12v | X | 20 |[/font]
[font="Courier New, Courier, mono"]GND | Y | 21 |[/font]
[font="Courier New, Courier, mono"]GND | Z | 22 |[/font]
andrew96
899CR
If your etching your own pcb then do make sure you do those power and ground lines as thick as you can, especially ground and the 5v line!
