AfterBurner Control Panel Questions
dj_yt
787CR
Yep, I've had this machine for just over a week and I'm already pulling it to pieces.
I'm not going to have time to do a full restoration anytime soon, due to baby 2 arriving. However, I'm going to clean the control mechanism, tighten up the controls and try to sort out the wild wiring.
A few questions:
1/ Can someone with a tidy machine take a snap of the mechanism for me? I have the two editions of the manual, but you can't beat a good photo.
I'm particularly interested in the area I've highlighted in pink where the mechanism is coming apart and the bolts/nuts have obviously been changed at some point in the past.
2/ What's the fastest way to remove the front plastic plate? I'm sure I'll figure this out, but if someone can remember that would be great.
3/ I've spotted a few fractured bits of metal. I may get them welded , similar to my OutRun restoration. But if you're sitting on a spare CP, let me know.
dj_yt
787CR
Cool thanks. I'll drop you a line depending on how I get on! I won't need anything detailed - just remove x first then unscrew y etc.
dj_yt
787CR
I think the above must be a sitdown as it's slightly different?
Also the top sections seem to be a bit different (highlighted in pink)
Bottom screws also seem to be missing on yours.
