Alligator Hunt sync issue
ebebop
4CR
Hi all,
First post however I have been a reader for years on and off as i never had any arcades, I now have a small collection with a few problems.
I have a Alligator hunt jamma board it plays as I can hear sound ect but I cannot get it to sync to the wells gardner 15/25 htz monitor other games are fine.
Any tips where to start? I have a multimeter and a logic probe.
https://youtu.be/XqXq7eMT82oebebop2018-08-15 07:28:22
ebebop
4CR
Hi, it doesn’t roll just a scrabbled image, I could almost make out the main sprite when I started a game. I’ll sort a video out tomorrow.
One thing I noticed when adjusting the v sync it went to a vertical collapse like as if the monitor was faulty. No other game board does this.
AaronBoone
165CR
It's possible the game has suicided - if you look here and scroll down to Gaelco it says:
Dead Battery Society said:
Gaelco, an arcade manufacturer in Spain, most famous in the US for World Rally and Great 1000 Miles Rally 1 & 2, made heavy use of suicide batteries. Their batteries are particularly nasty. They used a Dallas Semiconductor DS5002 microcontroller to protect their boards, which has up to 128k of battery-backed RAM containing a program for the 5002 to execute. This program actually patches bits of the main CPU's code. If the battery dies, the 5002 no longer makes the correct patches and the game won't run. Typical symptoms of a dead battery are a "coprocessor not responding" message and/or a loss of sync. The game will still show their demos, but eventually lock up. They will not be playable. The games known to have suicide batteries are:
World Rally
Alligator Hunt
World Rally 2
Touch & Go
Maniac Square
Thunder Hoop 2
Strikes Back
Glass
And the following may have batteries, but have not been verified:
Target Hits
Salter
There is currently no fix for these games other than to send them back to Spain to be fixed. You might have success replacing the batteries before they die. (Make sure you maintain power to the battery contact points at all times when replacing the battery). *update* Lutz Blasinski from .de wrote to say he successfully revived an Alligator Hunt by replacing the 2 Eproms :44n and 45n from his PCB with the MAME unprotected Roms: ahntu44n.040 and ahntu45n.040. w00t™
You could do with trying it on another monitor if you have one to see if the problem follows it.
ebebop
4CR
I tested the battery last night and I think it was showing about 2.5volts.
I can plug it in another machine the screen has colour issue but will sync to other games.
6,093CR
Listen to gunblade. He knows monitors.
ebebop
4CR
I've just realised that gunblade is the man who repaired this monitor and fantastic service. Btw grant its Paul from derby and the colour issue in the corner was the grid inside the the tube that had moved. A replacement tube sorted it.
I’ll be finding as soon as I’m home tonight about the ground pin.
Thanks for help so far guys!ebebop2018-08-15 12:19:43
gunblade
9,148CR
video ground is correct, have you tried the game board on another monitor?
trying to work out if the game board is the issue rather than the monitor- possibly a broken component on the sync output
ebebop
4CR
I have 4 untested arcade cabs in storage that might be coming your way if they don’t work.
The monitor I’m using is one you repaired and it’s fine with the following jamma games, midnight resistance, crude busters, bad dudes, dj boy and a Neo Geo.
I will try over the weekend to test the board in the other machines.
