Alpha mission 2 Error
Rob_bob_2k6
3 (71%)
225CR
Hi Guys.
I’ve gone to play my copy of alpha mission 2 on my mvs 4 slot and it’s giving an error and won’t load. It was working fine last time I tried it.
The error reference is address error 00019559e.
I’ve had the cart apart and cleaned the pins, it wasn’t very dirty and didn’t make any difference.
Has anyone had the same or similar and managed to fix it?
Thanks for any help.
Rob_bob_2k6
3 (71%)
225CR
Hi Dave, thanks for your reply.
All other carts are fine, I’ve got about 25 and not getting the same issue with any other.
Voltage was set to 5.11 last time I adjusted it. The neo sd still works which is a bit more power hungry so don’t think it’s a voltage issue.
It’s a 4 slot, MV4FT2.
Was hoping it was just going to be a leg on a rom chip needing reflowing :)
7,230CR
Yeh just incase it was the main pcb - I would say the CPU rom probably gone. Not much in the carts just roms and its rare tracks go. If you have cleaned the contacts there aint much more you can realy do apart from remove and check the roms if you can ?
Rob_bob_2k6
3 (71%)
225CR
I don’t have any equipment here beyond a soldering iron so I’m probably gonna list it on eBay as faulty and buy a new copy. Bit of a bugger think it was £80 around November time. Joys of the hobby I suppose.
7,230CR
Doubt it be the main board David , Especially if it just stopped and all other games ok. Stranger things have happened though. I have one MVS 1 slot that will play anything that is not in a clear case !! lol. I think it to do with the security chip but not messed as yet as.
TheDaddy2022-08-09 18:35:25
neo-geo-mvs
24 (100%)
932CR
With these early carts the cart sometimes need to be put into the slot fully and then lifted slightly to get to work.
Dave's technical while I'm just trial and error, lol :)
Cleaning carts etc usually worked for me and the mobo. Only had 2 carts that I couldn't get to work.
Rob_bob_2k6
3 (71%)
225CR
I did try inching it up and down to a few different spots and still no luck I’m afraid. My cyber lip is a bit dicky as a few are but just couldn’t make this one work anymore.
