Another Dead K7000
Chopper79
668CR
K7000 19", was working perfect 3 weeks ago. Now dead with no neck glow and no B+ voltage.
Fuse not blowing
Hot tests ok
Safety cap tests ok
D18 -D12 ok
Ceramic fuses removed and tested ok.
Looks like replacement flyback and cap kit already done.
125v input voltage ok.
I'm at a total loss on this one. Only thing I haven't checked is the voltage regulator.
It was working perfect and only switched off for 3 weeks.
Any ideas?
Chopper79
668CR
Ok, went over a few suspect joints, but nothing obvious. B+ is now showing 127 volts DC (At blue cable end) and 167 volts dc (At red cable end)
Still blank screen. Can see a faint glow from neck if lights turned off.
gunblade
9,085CR
i reckon its going to be the flyback, i had a chassis recently with your exact fault and the flyback was almost new
only way to prove it is replace the flyback
personally the first thing i would do is dummy load the HOT , check b+ and if still above 123v then desolder b+ pin on flyback and dummy load the b+ line
Chopper79
668CR
Thanks for your help grant. I'll get one on order.
Chopper79
668CR
Just an update. I found the red wire from the flyback going into the neck socket, couldn't have been soldered in properly, as it broke off removing the neck board. I stripped it back, and resoldered properly, and now when monitor on, I get a bright horizontal white line through the screen.
Chopper79
668CR
Replaced IC3 vertical IC, no change! I can hear a faint hissing noise coming from anode cap. When powered off, no charge on anode cap, as always check with screwdriver, but nothing. Can literally power off, and just pull cap off, without discharging! This chassis is becoming a Nightmare!!!
