So I bought the faulty Mr Do form Paulv because I have been looking for some PCB's to fix.
I recently acquired a Nascom 2 from ebay untested then spent a few months fixing it (with A LOT of help from the dudes at the Vintage Computer forum).
Anyway I enjoyed fixing it and I now have an idea how 8 bit digital circuitry works so I wanted something else to fix to gain more experience.
I got a Xain'd sleena non worker off ebay but fixed that in 5 minutes because it just needed the eeproms pushing back into their sockets.
So I got this Mr do off PaulV and it's given me lots more fun.
Made an adapter for it as it's not standard jamma that just does power and video at the moment and fired it up and got garbage as expected.
Checking the z80 I found the reset pin (26) was sitting low.using my basic USB oscilloscope plugged into a laptop I found the 555 (C1) that handles the reset pulse was working but the signal was not making it through the inverter (pin 3 to pin 4 of B1 a 74LS04) so I replaced that and the game booted up:
EDIT:Video embed does not seem to be working.Here's a link:
https://www.youtube.com/watch?v=gy6WLHo8d_4
But I noticed that all the sprites have a line of corruption through the middle.At first I thought it would be a data line from the character eeproms being stuck but then I noticed that the lines are static relative to the background not to the sprite.
If you watch the video carefully you can see that when a sprite moves up or down the playfield (or left or right because the image is sideways) the line 'scans' through the sprite but actually remains stationary relative to the rest of the screen.
I'm thinking it's video ram that's at fault now so will have a look at the ram chips next.
just wondering if anyone has seen similar graphic glitches and found a solution?
Lurch6662017-08-22 00:56:55
