Another outrun long shot
tin
673CR
I have (well had) an outrun board in my DLX that I understand was previously repaired by Retroclinic then stored for a couple of years. I relatively recently powered it up, at which time it worked for about an hour, then all the car & side-of-the-road graphics went all corrupty (that's a word right?) and, shortly after, disappeared
At the moment those graphics (Car, side-of-the-road, big outrun logo in attract mode) are gone, and a very very occasional corrupted graphic seen. The road, sky, letters etc are all there and - as far as I can see - are perfect.
My very much man-in-the-street understanding is that outrun pretty much has 2 graphics outputs that are merged together - a bit like the megadrive and the 32x (my favourite analysis of which is here https://www.youtube.com/watch?v=VvR_3OTxs8A at about 3m50*). I know it's not quite the same thing but it's the closest thing I can think to describe.
So I wondered if anyone knows if...
(1) this is a common thing
(2) if there's a simple part of the circuitry that mixes the two parts together where I could start.
I'm not against sending it to Mark again (if he'll take it on) but wondered if it was something relatively simple first.
* contains effing and jeffing, volume down if you're at work :)
tin2017-06-14 23:29:41
dj_yt
787CR
It sounds like a component in the sprite circuit has gone from your description. Its unlikely to be a socketed component, so unless you have an easy way of working with these boards on the bench I'd send it to Mark.
