Any BBC B experts on here?
virtvic
The Cabaret King
21 (96%)
1,972CR
I recently got a BBC B Master Compact and have no disc drive for it.
Is there a way of burning a 'game' eeprom to fit in the rom sockets inside the machine and can be played?
I am a total noob with this thing, btw...
bonehead
I'll get pix tonight
49 (100%)
1,714CR
I am sure when I bought mine back in the day it needed a dfs chip installed in order to use a disc drive. I told my dad I only wanted a cassette player as no one had any docs to copy, then found out ibwas the only one without one!!!!!
I still have it in a drawer at my dads. Would love to play Frac on it again someday.
Hope that helps.
virtvic
The Cabaret King
21 (96%)
1,972CR
Cheers Grob!
I found that exact one myself last night. I *may* treat myself to one
grobda
1,057CR
if you're after a cheaper more fiddly option you can hook up an ADFS beeb to a standard PC 3.5 floppy using a 44 pin cable without the twist, you will need to set the drive select jumper to drive zero (PCs are set to 1 by default).
you can then use omniflop on a pc to write disks that the beeb can read (ssd/dsd images). if your pc has a floppy
if you want even more faff there's a serial transfer program that uses the PC with the beeb as a slave to write disk images, but i've lost the website. it may be one of thiose linked here.
oh and http://www.stairwaytohell.com/ has all the games. some are available as rom images but ive never tried games from rom.
grobda2015-08-17 12:40:33
