Any interest in a Group buy in wigan 3x noir?
5,378CR
Shouldn’t the inside of that machine be covered in rust? Just talking from personal experience 😃
Mine has a little, mainly on top of the coin box and in a few other areas but it's down to they don't put a lot of paint on the inside
How are you getting on with the missing parts, did you get a door sorted?
Chihiro
1,004CR
My lit move strip panel was pretty coked up when I got it but cleaned up well with fairy I used LED strips on top of the old boards as most were gone & used 12v adjustable PSU so brightness can be tweaked.
channel27
1,369CR
No luck on the door, no.
This looks 1000x better now after a lot of sanding but this is what I'm dealing with!
All the steel that unbolts has been taken off and bathed in white vinegar. I could have drilled the rivets on the cash box but sanding will do for now. I really need to get it back together and tested. If only to fit this in the marquee!
eliotcole
1,118CR
You could even use cheap RGBW LED strip to illuminate them all (even on one circuit if you're clever, I reckon) and house them in (very) simple perspex housing (doesn't even need backing) then turn on this low power consumption lighting when entering the domain ... HUZZAH!
8,230CR
Brushed up well.
Yeh it’s getting there :)..
I’m really happy with the power side ..
I have all the power back as it was ..
So all switches work as they should ..
So cab can be turned on from the front switch behind the service door .
Wire it for jamma
And usa jamma to jvs ?
Mister would have to have a jamma expander as well ..
Just need to get back on ..
And a Naomi in ( sun psu is already in and ready , so is the sound amp ..
Then get the controls done ..
