Anyone fix Surface mounted PCBs ? (Maximum Force)
BGOllie
29CR
Hi,
I have a non booting Maximum Force PCB (PWR/RST led flashes on and off) . It's all surface mounted technology and well outside by ability to diagnose and fix .
Is there anyone who can fix these on here ? The pcbs seem tricky to find so I'd rather get it fixed.
Ollie
Ace`
PlanB contributor #1
40 (100%)
4,038CR
Are you sure it's a problem with the pcb and not the hard drive? If it's anything like killer instinct it won't boot without a working hard drive connected. Using a cf card / adaptor rather than an old mechanical hard drive is the best option.
BGOllie
29CR
it's got a CF card conversion kit installed already. Voltages seemed fine on the card connector so I assumed it wasn't the issue. I didn't check the contents of the card (assuming is this "standard" windows file format ? )
Ace`
40 (100%)
4,038CR
Finding someone that can surface mount solder is only half the battle, most of the chips are going to be custom and or hard / expensive to find.
You could carefully go around the chips with a toothpick pressing lightly on each pin to see if any are loose. As that's a common issue with smt chips, after that I'd say it'll be cheaper to buy a board from the states rather than trying to get it repaired.
AaronBoone
165CR
One has just popped up on eBay if you don't fancy messing around with the one you have http://www.ebay.co.uk/itm/182597747551 (sorry struggling to link from my phone). Don't know if that's a good price or not but you can always shove an offer in.
5,414CR
Might be in same boat after the battery leaked in our Jungle Jive machine, gone right down the pcb to the Surface mount IC which isn't good news
I used to do some Surface mount work when repairing computers, so may have to invest in the tools myself as I ain't got much chance getting replacement board
Repaired a knackered Grabber PCB not long back because the damn battery had leaked on that, managed to find a few tracks that it had eaten through
