So this white whale is doing my head in.
Picked up an APB from a barn, in rough shaped ( had squirrels living in it ) but a nice winter project.
Anyho, got the medium res monitor up and running, got CPU the board running after some cleaning, replaced Video board with one from Ebay. Power block is giving good power, rebuilt and then replaced the ARII board which didn't seem to be giving me -14v, again giving good power ( no audio though ). Getting 5v where is seems to want it.
The pain is the game will boot, and play but a) the steering is all over the place and b) the coin counter doesn't register. Also, when you go into the setting menus the "yes / no" ( toggled with the siren button ) will reset back every second ( as the same time the options will also reset to the bottom ). Can't get into any more options as the menu is controlled by the steering.
So working through common things:
Replaced optic board on wheel - same issue ( putting a scope / probe on the outputs and all looks good ). The coin counters etc all also registering on the board side as far as the first IC.
So I got another CPU board - same issue.
Got another ARII board - same issue.
Got another ARII board - same issue ( it was cheap ).
Got another transformer - same issue.
Got another video board - same issue.
Got a super sprint board CPU - replaced ROMS and Slapstick - same issue.
Got a champ. sprint board CPU - switched ROMS and Slapstick - same issue.
Got another super sprint board CPU - switch ROMS etc - same issue.
Got another APB video board - same issue.
Checked all the ROMS on the CPU and Video board - all good and checksums correct.
Have gone through 3 LETA's of each of the other System 2 boards - same issue.
Checked the harness the best I can - it all seems good
Running a probe on the board I seem to get a P2RESET on the LETA and various points on the board which is in sync with the resets on everything control wise. Again, the game itself plays fine in freeplay / demo visual apart from the steering and the fact I can't add coins.
Any ideas on what else to look for.
