AR1 Advice
ataridude74
265CR
I have done a repair kit on my AR1 on a US import Asteroids, standard Bob Roberts kit with the main 6 caps and 2 transistors only
Before hand the +5 voltage was dropping like a stone, down as low as 3V and still dropping, something had clearly died.
It's now rock steady but at 5.7v after adjusting down as far as it goes, that seems a bit high to me?
I have put a 100 ohm and 6v coin door bulb on as a load to test, it's still giving out 5.7v.
Bridging the sense pins brings it down to around 3.3v, with or without the load.
The Asteroids PCB is not connected. Maybe with it connected the load will bring the voltage down, but still seems on the high side.
