Ar1 high voltage
bonehead
I'll get pix tonight
50 (100%)
1,729CR
I have a spare atari Ar1 power board with high voltage.
It will not go below 5.72 volts.
I have only tested without a pcb as I was unsure if it worked or not.
I have tried turning it down but it won't go any lower.
Any idea what could be the fault? Should I change out the voltage regulator on the big heat sink?
Cheers,
Steve
RaveN
1,325CR
All ARs need a load to operate properly.
The LM305 regulator has a minimum load requirement for it to effectively compare.
Most people use wirewound resistors of a suitable resistance to test.
Looking at the schematics, it doesn't look like the adjustment POT will do anything if there's no pcb connected. The +sense line is connected to the POT and acts as the feedback to the regulator, and without a pcb the +sense line isn't acting as the 5v return path
It's not unusual to see readings of 8v with no load.
bonehead
50 (100%)
1,729CR
Ok I did think it needed a load!!!
It will turn up to 6.9v with no load.
What I didn't want to do was turn it right down then connect a pcb only to find out it's still stuck on 5.72v and get a pcb.
Thanks,
Steve
