Like other people have said, a burnt R29/R30 is due to bad edge connectors.
As an extreme example, if the voltage difference between the 5v and the +sense is 5v, then that resistor has to handle 2.5w. Some people recommend replacing that resistor with a higher wattage one, but that doesn't solve anything.
I'm guessing, but it looks like R6/R7 have burnt only due to their proximity to R29, and so just need replacing. I don't know of any cause that would make them burn, as they're only handling tiny currents.
Do a diode test on the 2N3055, and then just replace R29 and that should get you going again.
Andy
