Ar2 repairs
bonehead
I'll get pix tonight
50 (100%)
1,729CR
I have a number of games with ar2 and ar3 power supply boards. All are working fine at the moment.
My question is when is a good time to fit rebuild kits? I have enough to recap all my power supplies. Do I wait till they fail or is it worth doing them as I have the spares here?
A strange question I know but it seems when my games are running each time I try to improve things I tend to make them brake down,!!!
Just thought I would ask.
Cheers,
Steve
forcefulfil
EDOT King
17 (100%)
1,675CR
My atari line up are keepers.
so i treat them to a massive re cap/ reflow etc.
and any update mods etc.
that includes monitors power supplys and bricks.
hopefully to help prolonged life..
some folk think its a false economy.....
obcd
3,830CR
There is a saying "If it ain't broken, don't fix it"
The capacitors of a linair power supply are not under the same amount of stress as those of a switch mode power supply, since the frequency is just 50 or 60Hz. On a switch mode power supply, the frequency can be several hundreds of kHz.
Also, your machines aren't running 14 hours / day anymore, something they where designed 4. Due to that, the aging of the capacitors goes slower as well.
A monitor chassis is different as some of it's capacitors also need to handle higher frequencies. The environment of a monitor chassis usually also has a somewhat increased temperature. Doing a capkit on a monitor chassis can not only prolonge it's live, but can also increase picture stability and sharpness. On a linair power supply, you could check the output voltages for ripple. If that's non existent, it should work fine with it's capacitors.
