AR3 connectors and pinout
Purity
The Oracle
17 (100%)
2,998CR
Please can someone tell me what the female connectors are that plug into the AR3?
I thought I had found the correct ones at RS, ordered some and unfortunately they are wrong, so I'd prefer not to get the wrong ones again
Also can anyone confirm if the pinout is correct for the plugs?
Thanks!
Purity2017-12-20 15:23:15
Purity
The Oracle
17 (100%)
2,998CR
I've updated the image above with the correct pinout
The connectors that plug into this board are:
12 way - 1-480708-0
9 way - 1-480706-0
Crimps - 926894-1
Thanks to James RGP for pointing me in the right direction
smarty
Ready Player One
1,289CR
Thanks for updating your own thread Ben. Hopefully someone will find the info useful in the future. Even if they have to use google to search UKvac!
So is the AR3 for a test rig or is it going on a game?smarty2017-12-20 18:28:36
Jon-A-Tron
233CR
RS numbers for above for reference:
12 way RS 864-9789
9 way RS 084-8880
Crimps RS 720-2133 (edit: sorry this is wrong. These are the female sockets. I'll look again for the male pins)
Thanks also. I was looking for these myself and your part numbers did the trick.JonTron2017-12-20 20:10:05
Purity
The Oracle
17 (100%)
2,998CR
Hopefully both Martin, if I can get a Paperboy control panel at some point
Initially it's for a Paperboy/Champ Sprint test bench, because it needs weird voltages e.g +/-15v
Then hopefully I will use it in a scratch build if I can get the CP
