AR81 Owners
Zektor
312CR
I have been using my AR81 tester for a few weeks now and I have to say its a fantastic tool for PCB repair.
I have a few questions regarding commands and bugs that I would like to sort out. Are there any other users on here that own/use one?
I would like a full list of commands for the emulator, I've read the manual listed on the tester website and watched all of the online videos.
I'm also having trouble with the ID check when testing ROMs. The tester doesn't seem to identify the ROM and if I add the name to its database it still doesn't. I work around it by checking the DATA.BIN file using on online ROMIDENT with the testers internet browser at the moment.
I just fixed a Sega TacScan PCB set with it, plugged the emulator in, ran a MAP command and could see a bad RAM and bad ROM instantly. Swapped in a new RAM, cleaned the ROM and it fired into life.
Purity
The Oracle
17 (100%)
2,999CR
I have one, but I have to admit that I've not used it that much
I found that the ADT part of the tester, seemed to yield different results compared to HP comparator. How did you find that?
Also it would be great if there was a full array of logic IC's in the ADT library to test from
I believe Mark is working on things in the background but has been suffering illness.
He has been working on the AR16 with 68000 emulator
Purity2019-01-21 13:01:14
Zektor
312CR
Equites said:
Not seen one of these before, how does it differ from a Fluke setup?
It’s a PI3 running things with a analog / digital probe , logic analyser , emulator all in one.
You can use it standalone as it has a touchscreen but it’s easier with a monitor connected along with keyboard and mouse. The fact it has a Firefox browser is really helpful, for checking schematics or checksums.
There is a website will all the info but it’s missing the finer details.
I’ll post some pics of it in action when I get home .
Zektor
312CR
He has been working on the <span ="_5yl5"><span>AR16 with 68000 emulator</span></span>
Yes same results for me . I watched the ADT video but I’m not quite sure how the truth table learning part works .
I figured out how to add logic ICs and a gif of the IC to match, I like that you can see what logic is in the chip under test, saves looking it up in a book each time.
DKongPete
12CR
Same boat, would like to use it more and have a known good ADT database (which I think does exist somewhere online).
Has anyone tried theirs on Nintendo pcbs? Talking to Sarj it sounded like some issues are being identified, mine definitely has issues running known good boards (makes it tough to troubleshoot bad boards)...
Arcadenut
314CR
I own one.
Type "help" in the command window.
There is a bug in the software. When it calculates a CRC32, it doesn't pad the length of it, so if the length of the CRC32 is anything other than 8 characters it might not match anything in the list.
I'll take a look and see if I can fix it and post a patch to it here.
Arcadenut
314CR
WARNING! Use this information at your own risk.
ok, I went back through it and I remember what the issue is.
First is the file /home/pi/Desktop/ROMS/ID.crc is where all the CRC values are stored and it's a fixed file Format.
All the CRC values should take up 8 characters, however, there are several that take up 7.
If you take a look at line 84 (Assuming your file matches mine) you'll see:
F8C083Fdkjrbl - DJR1-V.7F
This should be:
0F8C083Fdkjrbl - DJR1-V.7F
The file also only includes a little over 2,200 ROMS that it can identify.
I've created a new file based on MAME .180 that has 182,828 ROM Identifications.
I'm not so sure it's a good idea to use the entire file as I think it will make the ROM Ident feature VERY VERY slow to the point where you may want to pull the plug :)
I think the other issue is the way the CRC is formatted in the code prior to checking. I could be wrong, it's been awhile since I tracked it down and haven't gone back through all the steps to verify this information. I don't think this fix will hurt anything, but it might also not change the behavior at all, thus being a waste of time.
If you look at test.py, this is the source code for the Tester on the AR81. Look for a method called CRC32. It should be on (or about) line 59. It will look like this:
def CRC32(fname):
At the end of the method it returns the value as this:
return "%X"%(prev & 0xFFFFFFFF)
Which converts the value in the variable prev (masked with 0xFFFFFFFF) to a HEX value in upper case. The problem is, it doesn't Zero fill at the start.
Now I'm not an expert on Python (I have only written a little bit of code for Fusion360 in it) and I haven't tested this, but the line should probably be changed to:
return "{0:08X}".format(prev & 0xFFFFFFFF)
I'm not sure how to attach a file here yet, so if I can't figure that out, I'll upload the new ID.crc file to my website and post a link here.
Arcadenut2019-03-10 08:48:07
Purity
The Oracle
17 (100%)
2,999CR
I would also like a known good ADT database of TTL maps. I believe Porchy made a tool to generate these maps
http://www.jammarcade.net/ar81-tester/
Do we want to find a place to store these and share out TTL maps?
Maybe we can store our own TTL maps in our own folders and then find a way to cross check against others to verify the maps are valid?
Purity2019-03-10 10:45:31
Arcadenut
314CR
Unfortunately, the ADT testing is limited. Anything that has a clock or stores state in the chip will probably not work correctly.
The issue as I understand it is that the ADT function simply looks to see if Pin X is in state A then Pin Y should be in state B. That works great for something like a 74LS04 where the inputs are strictly binary. If Pin 1 is High, Pin 2 is Low, etc...
It doesn't work very well with something like a 74LS74 because the chip has a CLK and a CLR signal which affect the output over time. You don't know what state the IC is in and therefore don't know what the output should be.
Hopefully I explained it well enough
Purity
The Oracle
17 (100%)
2,999CR
Yes I get it :)
Could you not create a map for different states over time to deal with that?
For example Porchy's TTL maps have two different states defined for 74LS74 - 74LS74_1 and 74LS74_2
Purity2019-03-11 14:23:39
Arcadenut
314CR
Purity said:
Yes I get it :)
You might be able to but you would have to track it from power up and I think the AR81 software would have to be modified to be more than just a lookup into a table.
Zektor
312CR
I own one.
Thanks!
Thanks again, I'll edit per your instructions.
I'm not sure if its normal or not but some of the functions shown in the video don't work on my unit.
"STUCK" does nothing and the same for "SHOWPINS"
I didn't know about the "DIAG" command, that work... very useful!
Arcadenut
314CR
Stuck and ShowPins should work from the ADT.
If I remember correctly, you run Stuck to see if any of the pins are stuck either High or Low. If your chip is functioning correctly, you won't see anything stuck.
The ShowPins should show you a snap shot of the chip at that point in time.
Arcadenut
314CR
I would take a look at one of these:
https://forums.arcade-museum.com/threads/fpga-cat-box.472988
http://www.ukvac.com/forum/topic349525.html
http://www.ukvac.com/forum/topic372995.html
