Arcade 1 up mod help
Weyboy1
2CR
I have a a arcade 1 up pac man machine and wanted to mod to a 60 in 1 jamma.
I think I have connected everything up correctly. The video converter works as I have connected it to a laptop via the hdmi port.
When I connected the vga to the jamma board I do not get a display. I have dip switch es 2 and 3 up ( on)
The only thing I can think of is the vga port on the jamma board is not working?
Any ideas please.
Weyboy1
2CR
Hi , yes I have tried plugging in a hdmi cable from the Jamma board to a monitor that I knew works amd get no signal on the monitor. This says to me the vga port on the Jamma is not working correctly??
Weyboy1
2CR
Fantazia2
2,246CR
It might help if you dont open a second thread on the forum for the same thing as people will not know if someone has mentioned something else or you have tried something else in the other thread you started.
From the other thread you have said you have tested the Arcade 1 monitor PCB via HDMI and that worked so we can discount anything to do with the Arcade 1UP for now, and you have tried plugging in the 60in1 to a VGA monitor and got no signal on that either, although you mention HDMI in this thread from the Jamma board and 60in1s dont have a HDMI connection.
How are you powering the 60in1 Jamma board, are you sure it is booting up, youve already mentioned in the other thread that you have set Dip 2 to on to set its output to 31Khz which should make it output 640x480, which pretty much any device that has a VGA connection should be able to display in some format.
Weyboy1
2CR
Hi Fantazia2 I have a Jamma board power supply for the Jamma board. The lights are on the board. But whatever I connect to it no display on the arcade monitor or a t.v monitor. There is only a VGA out on the board.
It’s very frustrating......
Weyboy1
2CR
I have tried 1 tv and a monitor. No signal from any of them. I hope it’s just a setting I need to do. There is only a VGA output from the Jamma board. I wish there was a way to test the vga port and it would work.??
Fantazia2
2,246CR
Sounds like it may be a dodgy board, I know the VGA port on the one I had years ago always output on the VGA port no matter whether it was set to 15KHz or 31KHz with the dip switch.
If its a brand new board I think the default is for them to play music once it has booted and showing the game selection screen (Takes about a minute and counts up or down the games on the screen) you could try plugging some headphones into the mini jack on them and see if there is any music after a while or try wiring a speaker to the jamma connector.
Are you sure you've wired the power connections to the edge connector correctly and have you checked your voltages.
The only other option is to plug it into a proper jamma cab with 15khz monitor to see if it displays anything, there is nothing to config on it other than dip 2 to switch between 15KHz and 31KHz.
Weyboy1
2CR
thank you for the good idea for lisining to sounds. Although the new jamma has not been configured to set up the games. Silly question but I notice the video wire which has 5 wires red blue green black ans whote connect to?
There is a 4 pin slot on the jamma board. But 5 pins on the harness with the white wire spaced from the other 4.
Does this connect to the jamma board?
Weyboy1
2CR
Thank you for the good idea for listening to sounds from the games. Although the new jamma has not been configured to set up the games. Silly question but I notice the video wire which has 5 wires red blue green black and white connect to?
Does this connect to the jamma board? Would I have to cut a wire out?
Fantazia2
2,246CR
The sounds I was referring to is the music that plays in the background on the game selection menu, by default I think it is enabled, so if its a new board it should be on.
There should be nothing else you need to wire up, the 5 video leads from the Jamma wiring harness are there to connect to an arcade monitor, the 60in1 board has video output on the Jamma edge connector and the VGA connector.
Not sure which other connector you are referring to but there is a white 4 pin one next to the VGA connector which lets you power up the board using a PC power supply as its the same type of connector that was on old HDD and CDRoms, the other 2 pinned connectors next to each other are for trackballs to be fitted.
Weyboy1
2CR
Hi fantasia2 so the 5 video wires fo not have to be plugged into the video converter. Just the VGA from the video converter to the Jamma board. I still have not signal on the monitor.
The light on the converter goes from green to red once connected to the Jamma board. The only time this went green again was when I plugged in a laptop from the converter.
I feel I have done everything right.
