arcadeandy
hey guys, ive wired up my arcade switch to turn cab on off but cant turn off its live both ways any help would b great many thanx.
Fantazia2 said:You probably want to remove all the wires from the input and test what is what on the switch using a multimeter in continuity mode and throwing the switch back and forth so you can work out which terminals are switched to which other terminals.
69er said:Fantazia2 said:You probably want to remove all the wires from the input and test what is what on the switch using a multimeter in continuity mode and throwing the switch back and forth so you can work out which terminals are switched to which other terminals.
THIS always have a multimeter to hand ... electric is invisible and harmful
pull the plug ....... and check out the switch is working ok and which terminals open when its off and close when its on
while its not wired to the switch make sure the wires are not touching each other or anything else and then plug in .... if the machine is 'on' when plugged in while the switch is completely disconnected then its a wiring short issue and the switch is just not effective... BUT GET THAT METER
