arcade rocker switch
arcadeandy
127CR
hey guys, ive wired up my arcade switch to turn cab on off but cant turn off its live both ways any help would b great many thanx.
Fantazia2
2,246CR
You might need to upload a larger picture than that, pretty much impossible to see what youve got there.
Also a better angle so we can see where the wires are going to.
Fantazia22020-06-30 11:13:46
Fantazia2
2,246CR
Still need a better angle, all I can see on there is 2 power leads that are joined together in the chocolate blocks on the left hand side of the pic going to what I assume is the switch on the right hand side.
Is there another cable for power in?
Fantazia22020-06-30 11:29:32
arcadeandy
127CR
hey guys thanx for looking ive tried to get better pics but no joy, all it is a kettle lead coming inn then earth live neutral, then their piggybacked to switch, then earth live neutral to power supply. sorry but just not very clear on explaining.
Fantazia2
2,246CR
That looks like a complete mess.
If the switch part is at the top and the kettle lead connection is at the bottom, it looks like you have a loop of cable going to both sides of the switch for both neutral and live.
That needs pulling out and redoing for the wiring as its all joined together at several points so the switch will never work.
Fantazia2
2,246CR
Basically you want it like this.
If the bottom connectors are from the kettle lead and the top 2 sets of connectors are the switch then,
You want jumper wires from the lower terminals to the bottom of the terminals on the switch.
You then want to get rid of one of the black wires as it is redundant.
Then wire the remaining black wire to the top set of terminals on the switch and the ground wire to the ground post on the lower kettle lead connection.
That should then give you a working power switch.
Presently you appear to have the lower terminals connected to one of the black leads which is giving you a permanent live into the cab, then from the chocolate blocks that the lower black cable goes to the other black cable is also connected to so the live power goes to the top terminals on the switch and then you have jumper wires going from one side of the switch to the other, so no matter what the switch is set to you will always have a live connection on all 3 sets of terminals.
At least thats what I can see from the photos anyway.
Fantazia22020-06-30 13:15:27
7,230CR
Cant tell what sort of switch it is - the live is basically just looped through. I would start again. What is the front view of the switch ??. This is how (Most) work (Basic but good indication) :-
More than 1 type of switch though.
EDIT :- so basically looking at your other pic the switch is doing nothing as L/N/E come straight out of the rocker IEC input and go straight to the Block connector that supplies the 2 Outputs (I assume 1 screen and 1 PSU) The should only be 1 black wire from the switch - you have 2 ( As far as I can make out)
TheDaddy2020-06-30 13:31:07
Fantazia2
2,246CR
You probably want to remove all the wires from the input and test what is what on the switch using a multimeter in continuity mode and throwing the switch back and forth so you can work out which terminals are switched to which other terminals.
Going by TheDaddys picture it looks like a similar unit but upside down, and the switch is wired 90 degress.
I dont think yours is wired that way as if it was and you flipped the switch you would essentially be joining the live and neutral wires together when on causing a massive short with how it is currently wired.
69er
1,854CR
THIS always have a multimeter to hand ... electric is invisible and harmful
pull the plug ....... and check out the switch is working ok and which terminals open when its off and close when its on
while its not wired to the switch make sure the wires are not touching each other or anything else and then plug in .... if the machine is 'on' when plugged in while the switch is completely disconnected then its a wiring short issue and the switch is just not effective... BUT GET THAT METER
Fantazia2
2,246CR
From the pictures it looks like both sides of the switch are jumpered together so it will never work.
