Area 51 stopped working
seanr28
9 (100%)
319CR
Hello All,
I'm still fairly new to the arcade scene, however I need some assistance please
my area 51 cab appears to have just died, not really had a chance to look at it in detail, but after switching on you get nothing on the screen until around a minute or so at which point you are greeted with a load of white numbers / letters and the only part that makes any sense is at the top left of screen which states "PC reset" any suggestions please?
Thanks in advance.
Sean
stevebm1
39 (100%)
1,269CR
the area51 pcb is very voltage sensative,there are two leds on the board which tell you if your voltage is to high or two low,try tweaking your 5v on your power supply,I had a similar problem and it was down to that.also your hardrive may have failed,could you not make another?,it's easy to do with chdman
