Asteroid questions
bonehead
I'll get pix tonight
50 (100%)
1,729CR
I have powered up my asteroids for the first time in a year. I bought the monitor from a member on here which is a wg v2000.
The picture is back to front when in the cab. I remember being told that I need to ground a pin to flip the picture from left to right. Not sure which pins it is?
Also the pcb plays fine but I have no flashing player 1 an 2 buttons.
Game credits up and you can select players fine. I have checked the LEDs with known working ones from missile command but they just don't light up in the asteroids cab.
Could it be a pcb fault?
Any hop would be appreciated.
Thanks,
Steve
4,058CR
Is it an Asteroids cab or a Deluxe cab? I've had many asteroids boards go through my hands and don't ground any pins to get the picture the right way round.
If it's a cocktail cab then there's a pin you ground to get it to flick the picture for player two, but not from left to right or anything. Doesn't sound like the monitor is wired up right to me. Or it sounds like something isn't wired right!!
[EDIT] Regarding the LEDs. It could be a PCB issue but it more likely to be the case that the wires are not connected correctly on the cone switches. I seem to remember it's pretty confusing and not overly obvious. To be honest, the wiring sounds a little suss in this cab...
guddler2014-01-22 23:11:15
tb lilley
5 Star
1,686CR
Re: the reversed picture. The monitor yoke plugs in to P701 on the deflection board. Pin 1 (black) Pin 2 (yellow) may have been reversed. If so, swap them back. If not, swap them anyway. That should sort it out.
bonehead
50 (100%)
1,729CR
I will try the yoke pins today. It is an upright cab which I am sure is just an ordinary upright. Does anyone have a pic of the buttons and what wires go to the correct pins on the buttons.
Cheers,
Steve
4,058CR
You'll find the + and - is embossed on the switch housings, and it's all marked in the wiring diagram so really, you just need to look at it and suss it out.
5,658CR
If it is a WG2000 from an Asteroids Deluxe then the monitor is set for picture invertion from the factory due to the mirror.
Do as tb lilley suggests.
