Asteroids AR board recap?
Wahoobies
498CR
Is there anyone on the forum that people might recommend to re-cap/service the AR board from my asteroids? I've got a tiny wibble on my test pattern that shows up with the original PCB (pictured), though it didn't show up on test bench with scope.. and also doesn't reproduce if I plug in masteroids and use test patterns. in-game, that spot particularly gets that glitch on the rocks/ship/other vectors. You can see it's sort of a distortion line right there at X=0 and negative Y axis all the way to the bottom
Mark at retroclinic suggested it could be the AR board producing some riples in output voltage on the higher-draw original PCB. any recommendations appreciated
Nes4life
1,134CR
Also, it's an x-axis issue, so that narrows it down to the x-axis DAC or it's supporting ICs. Likely to be in the high voltage / analogue section as Equites says above. I'd socket the 3 iCs in that area and switch them out, or also socket their Y-axis counterparts and swap them in pairs; then you'll likely find the culprit within a few swaps. Great if you can do this yourself otherwise it's something I can do.
Wahoobies
498CR
Thanks everyone, this is very helpful.
The main thing that has been confusing me -it looks fine on Mark's scope (see retroclinic video) so I thought it was unlikely the asteroids board.
To test the monitor itself (G5-805), I used my masteroids board . That is not showing the problem. I get good brightness/contrast/Z on it, and test patterns look good in that area.
Plot twist- I had slight "breathing" on the screen (get smaller and larger at corners) for a while, then a sporadic "Fade to black" on the screen. I replaced F6 at advice of some folks (the fuse for the heater) and this fixed the fade to black. Also I notice when it's warmed up for a minute or two that breathing in the corners is gone.
Does this add up? I really appreciate all the input as I'm not knowledgable, but really enjoying learning and being careful to stay inside my own limits
