Asteroids Cocktail - ALL FIXED!!!
cparsonsuk
205CR
Ok, so my Asteroids Cocktail stopped showing a picture about a year ago and it's making me sad! It still powers up, plays sound and you can start games but no display.
I've tried the obvious reseating chips, checking brightness and leaving it running to no avail.
When I bought it over 10 years ago I paid someone from the old email ukvac to take the monitor away and recap it so, based on home usage rather than commercial, I would be surprised if it's those that have gone bad but I don't really know.
I have no skills or tools to test voltages and suss out what is wrong so would like to pay someone in cash or PCBs to troubleshoot and fix it if there's anyone reasonably local.
It's a really nice clean machine, all original boardset... I replaced the glass, got an aftermarket underlay and screen bezel and fitted a high score module and would love to get it going again.
If anyone might be able to help please get in touch... location is Reading, Berkshire.
Cheers,
Chris / cNp
Look how happy it was on my 40th Birthday...
Asteroids Cocktail Table Arcade by Chris N Parsons, on Flickr
cparsonsuk2015-12-06 20:41:58
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
those vector stuff is really a specialised market for repair
not many people will look at them
not sure if there is anyone that repairs vector monitors
silverfox07862015-04-24 12:40:24
cparsonsuk
205CR
Hmmm, yeah, that's what I'm worried about... I'm hoping it's actually nothing too serious and someone can make some easy cash / get a nice PCB or two for minimal work!
cNp
Equites
Chief Sheesher®
35 (100%)
3,329CR
How do you know the monitor has failed? A PCB failure can exhibit the same symptoms.
Where are you based?
EDIT: Ah in Berkshire.Equites2015-04-24 13:03:20
Stevros
506CR
Checking fuses on monitor and psu would be the first step.
There's nothing too these monitors, hardly specialised equipment so I think someone who fixes normal monitors would be able to work on it for you. Stevros2015-04-24 14:34:57
  • Like
Reactions: cNp
Ronnie Dent
1,206CR
Check for neck glow on the tube, is the spot killer led on? I'm no expert but I know the screen suffer from cold solder joints on the plugs well on my deluxe anyway if it's the same screen
Ronnie
  • Like
Reactions: cNp
cparsonsuk
205CR
Hi, thanks for the replies so far.
Checked a couple of things based on the replies...
There is a glow in the neck of the monitor
The spot killer LED on the monitor deflection board is OFF (took me a while to find it which is a pretty sure clue it's probably not lit!)
So the spot killer being off is good... right... as it hasn't needed to be engaged to protect the screen. Maybe it is 'just' a fuse that's gone.
cNp
cNp2015-04-25 12:00:32
cparsonsuk
205CR
Update: I just took the fuse out of the main power board (the one that's hidden away and you have to 'screw' out the top bit that holds it in and it looks like it's blown.... perhaps it could be as easy as that!
Checking the schematics I have it also looks like the fuse should be 7A and the one in there is 3A.
cNp
cNp2015-04-25 12:28:27
cparsonsuk
205CR
Hmmm... no dice... gonna get replacement Fuses for all the ones on the monitor board tomorrow and see if changing them all helps any. Also just checked and at least one of the 5 fuses on the power board is blown ... basically I'm buying all new fuses in Maplin tomorrow!
cNp
cNp2015-04-25 20:16:24
cparsonsuk
205CR
Ok... all fuses replaced on the power board and monitor board... sound is now back really loud and clear... there's the proper buzz you get when these things are powered up which was really missing... everything feels like it did when it was working ... but still no picture showing.
All of the fuses on the power board were the wrong Amp rating and 3 had blown and been wrapped in foil to make them work!!!
It feels close but ... will have a read up on what to check next but I'm probably past what I am comfortable doing myself now.
I did take some nice pics inside the cab whilst I was at it though :) (https://www.flickr.com/groups/2800674@N20/pool/)
Atari Asteroids Cocktail PCB B&W by Chris N Parsons, on Flickr
cNp
cNp2015-04-26 14:56:45
big10p
Coins detected in pocket!
6,085CR
Mitchell Gant
888CR
cNp
Some of that buzz you hear is the deflection coils around the picture tube when the game is working normally. The buzz should change tone as the game goes through it's attract screens. That along with the spot killer LED on the monitor being OFF says that the game PCB and monitor deflection boards are getting power and working OK.
That could mean that the high voltage section of the monitor is faulty. You have neck glow on the CRT, good. You could try slowly turning up the brightness and contrast knobs and see if any dots or lines appear on the screen. If yes then HV section is working, if not then may be faulty.
Be careful turning up the brightness though, there are some high voltages around that area so you don't want a shock off it, or damage it by pushing a metal screwdriver too far through the control pot and shorting out parts of the circuit. Look where the controls are with the game unplugged and get familiar with turning them with a small screwdriver avoiding holding it's metal shaft.
Also if you turn the brightness up full and a bright dot appears in the centre of the screen you can burn the CRT permanently, so do it slowly while watching the screen and turn back down once you do see a dot in the centre. Or get someone else to watch the screen while you keep your eyes on what your fingers are doing on the controls!
If no dot or lines appear then possibly the HV circuit that has failed. That's the part caged in a perforated metal box on the monitor. There are other faults that could also cause this, but a failed HV section sounds most likely.
  • Like
Reactions: cNp
cparsonsuk
205CR
Thanks Mitchell. I didn't like the idea of adjusting the brightness whilst the machine was on so I tried the controls in various positions, turning off then on again in between. The pots have a surround that allows me to turn them without a screwdriver
I could have missed a sweet spot but I never saw any lines or dots or anything.
The game is playable blind, all sounds, controls, 1 & 2 player select work... it also beeps in test mode when I press the 1 & 2 player buttons. The game PCB's red LED is lit when the machine is powered on too.
If it's something failed in the caged off section I think I'm going to be back to my original request for someone I can pay to try to fix it.
cNp
cparsonsuk
205CR
Just a bump on this... if there's anyone I can pay to have a go at fixing this I'd be happy to drop it off and leave it with someone or cover costs to travel plus payment for fixing.
Really want my Asteroids back up and running.
cNp
cparsonsuk
205CR
Cheers for the quick reply... got a PM from smarty who is fairly local and he's very kindly offered to have a look and see if he can help.
cNp
Nes4life
1,134CR
The next step i'd probably go down is trying to prove if it was the pcb or the monitor. I'd ask to see if anyone was willing to test the PCB in their own vector cab. Otherwise borrow an oscilloscope with X and Y inputs and see if you can get a picture on that.
VectorGlow repairs PCBs professionally (not sure about vector games though):
http://www.ukvac.com/forum/topic329811_post758371.html#758371
I'm not saying you should do this but there are a few classic PCB repair services advertised on your favourite auction site (best to stick with the forums).
  • Like
Reactions: cNp
