Asteroids cocktail!
urbanledge
95CR
So my uncle picked up an asteroids cocktail and Im going to help him get it going.(hopefully)!
went to see it today and my god its lovely.
even better its 100% complete.complete. Dont think Ive ever seen something so complete.
production number 68!
anyway opened her up and its very very clean inside.
couldnt see any dodgy looking caps etc so decided to fire it up .
without the pcb I get a white don in the center of the monitor.Guessing this is good?
with pcb the dot seems to be off screen and flies in when I switch it off.
led comes on on the PCB and the speakers make a scratchy kind of noise.
Volcano buttons light up.
I popped off the socketed roms and have found 2 broken legs rusted through.
I dont think I have the skills to fix the pcb so who do you recommend?
also any way to test a vector with out a PCb?
thanks
backflipper
774CR
Dont leave the monitor on if your getting a white dot in thr centre of the screen, it will burn the phosphor of the inside of the tube and leave a permanent black fot in the middle.
It sounds like you have a monitor fault and a pcb fault...
4,058CR
I would not say you necessarily have a monitor fault. But it's possible. You need to prove one or other or both first and the only way to do that is to either rig the PCB up to a scope to prove you are getting a good picture from the PCB (in which case you have a monitor fault) or you hook a known good PCB up to the monitor.
Actually, you could even have a PSU fault. You could also do with establishing that you have 36VAC (centre tapped) coming from the transformer in the cab and that the voltage regulator section of the PCB is successfully producing +/-15v, +5v (DAC) and +/-8.2v before you really know if you have a PCB, Monitor or PSU fault, or any combination of the above. Not the most straight forward of things to establish straight away with no replacements.
What kit and knowledge do you have?
urbanledge
95CR
Hay Guddler,
Im going to get the everything out of the cab later so I can clean it up and work on it.
I'll cap the lot for him anyway and test the PSU output and see whats going on.
Knowledge wise Ive never done anything with vectors before so its 0 .
Would the PCB be something you could take a look at?
I feel its out of my league and I can see it needs new chips.
