Asteroids deluxe- randomly switching off
Retrojedi74
91CR
Hi All, wonder if you can help?
I recently purchased an Asteroids Deluxe cab which has been converted from 110 volt to 240 and i have had the cab on a few times since ive had it and i have returned to cab being completely off. So ive had a look at engineers switches front and back to see if they were the problem and they don't seem to be causing it i don't think. ive switched the cab on trying to see if it will switch back on a day later and it comes on fine and plays fine but then a few hours it does it.
it is very random and i was wondering what i could check to solve the issue.
Thanks in advance
DanP
Administrator
2,232CR
With the interlock switches - how did you test them? They work in two ways, firstly mechanically by the plunger being pushed in - usually by a coin or rear door. Secondly you can pull the plunger and lock it in place (with the doors open or removed). I’ve seen random power offs caused by interlocks not being fully pushed in by the rear door because it’s loose or the interlock has moved. Pictures would help for sure.
Dan
