Asteroids Fail
virtvic
The Cabaret King
21 (96%)
2,012CR
Turned on Asty today to checkk out for visitors coming this weekend and
PCB fault (Asty Dlx ok and now installed)
Any pointers where I should start. Test mode passes ok.
RGP
Meeter & Greeter
2,039CR
Test mode is only upto the reading of ROM and read/write of CPU accessible RAM.
So this would be in the drawing side of it.
Mitchell Gantt is your guy here as he understands that side of Asteroids really well - I've sat and had lengthy conversations with him about "the state machine"
Mitchell Gant
888CR
Could be a Y position counter that's failed. If you've got a 74LS191, and your PCB has a chip marked the same at location H9 and F9, you could try piggybacking each of those in turn and see if it improves the test image.
4,058CR
Only thing I'll say is, you can't always piggy back 191's. So you may be looking for a clue it's getting better rather than piggy backing one and it actually fixing it. Did that make sense? I know what I mean, I might just not be getting it across too well!
I'd agree with Neil in that it looks like the best area to start though. Maybe it's something feeding or being fed by the 191's if it's not them. To be fair I've not looked at any boards for quite a while.
4,058CR
No, if it made no difference at all then I wouldn't bother. What tools do you have? Can you check the 191's with a scope for example and make sure their outputs are doing what they should be? Or do you know have enough to be able to do that?
Much beyond that I'd need the board in front of me to make any desperately useful suggestions.
