Asteroids issue - help please !
Mark H
98CR
Hi All,
My Asteroids cabaret now has a fault having run without issues since July 2014 when I bought it! The two player 1 and 2 cones are flashing quickly together at the same time and I have no sound or screen display. The coin door lights and bazel light are fine though. When I do a self test all I get is a beeping sound every two or three seconds and still no screen display.
I'm not a technical expert here so please could you advise are there any quick wins or I will have to call in the experts !
I do have a spare PCB which I may try tomorrow (when I find it) to see if that works though.
Mark
Nes4life
1,134CR
Might be worth reseating the ROMs just in case one is making bad contact. If you're not technical then that's probably as far as you want to go. You could connect GND to WD Disable with a croc-clip to see if it's a fault in the Watch-dog circuit. After that it's work-bench time.
Mark H
98CR
I had an LS08 chip failure in the end which is part of the vector state machine hence no picture !
Ah well the PCB is 40 years old and it now works again !!!
