- Credits
- 765CR
Can anyone help? I'm stuck.
I have no sound from my Asteroids, I've changed the LM324 op amp at P11 but still nothing, none of the sounds seem to be there.
If I look at THUMPSND I can clearly see the signal up to R83, on the op-amp side of R83 I can barely see the signal on the scope and on the output P11 pin 8 - nothing.
I socketed the op-amp and tried 3 different ones.
I also lifted all the resistors that the other sounds feed through (R77, R78, R81, R82, R84, R102) to see if one of the other sound circuits was killing it, but still no sound.
I lifted the 1uF tant at C113, still nothing on the op-amp output at P11/8
I've checked all the resistor value - all in spec.
Running out of ideas here!
