Asteroids PSU help
Lurch666
21 (100%)
4,517CR
I'm fixing an asteroids PCB and it's the first vector PCB I have ever tried to fix.
I don't have a vector monitor but hope I can at least get something on my oscilloscope.
The main problem is I don't have a PSU for it.
I can easily provide the +5V for the TTL but for the vector output I need 36V ac in.
looking around I found an old thread about using a 36V transformer but the transformer GND needs to be connected to the common GND on the PCB for it to work properly.
Now since the 36V is AC there is no GND unless I use a £36-0V-36V transformer but can't find one.
Could I just get a 36V single transformer and connect the AC output to the pins X and 10 of the PCB or would that not work.
yorkshire_spam
765CR
TBH it's not that critical that it's 36VAC. I think it's effectively a 18-0-18 CT arrangement.
I run vector boards on my test rig (including Asteroids) using a centre tapped transformer putting out about 40VAC.
(For boards expecting DC I just feed that through some rectifier diodes and some smoothing caps to give an unregulated DC of +/- 28V)
So if I were you I'd look for a 20-0-20 transformer of some sort (or similar)
Lurch666
21 (100%)
4,517CR
So would I connect one outer tap (20V) to one 36V pin on the edge connector and the centre tap (0V) to the other 36V pin with the centre tap also going to the GND pin of the asteroids-the same GND that the +5V DC is connected to?
yorkshire_spam
765CR
CT and GND from my switcher are both connected to the GND on the PCB edge connector and the taps either side of CT are on pins X and 10 (both labelled 36 VAC )
Cheers, Sam
EDIT:
Diagram Added
CHECK THE PINOUTS!
yorkshire_spam2020-12-27 19:34:10
Lurch666
21 (100%)
4,517CR
Success:
I ended up using a 12V-0V-12V isolating transformer since I wasn't sure if that would mean 24V going into the board or 12V so I decided to use a lower voltage just in case but as you can see it comes up on my scope fine.
Going to add amps to test the sound FX and patch in the controls but after that it's as far as I can go since I don't have a vector monitor but it's been fun sorting out my first asteroids board.
Thanks for the help and thanks to Forcefulfil for the board.
yorkshire_spam
765CR
Nice work!
If you want to confirm the AC voltages... Set your multimeter to AC volts, measure between the 2 outer AC terminals and then measure again between CT and each output....
You should see 24VAC when measuring the 2 "outer" terminals and 12VAC when using the CT
Lurch666
21 (100%)
4,517CR
Yep I did that before I connected to the PCB but since I'm not experienced on this side of electronics I don't know if the board is getting 12V or 24V.
But since it's working and not exploding I'm assuming it's within tolerance.
yorkshire_spam
765CR
I think 12-0-12 is probably close to the low-end of working, you might find if the line level drops it stops working:
The +/-15VDC is probably right on the edge - worth checking the outputs and maybe consider a 20-0-20 if you can't get stable 15VDC
Nice work getting it up and running on the scope though!
