asteroids ram problem
Aspire
16CR
I have a problem in a vector ram, is rare because i change rams for new ones and still there, otherwise if i dont put any ram in 4 tested ram, test says 3 ram is good, but if i put ram in position 4 test says that 3 ram is bad.
Any ideas?. I have tested roms, both buses to the buffers, etc. I think it could be any adress line used in vector zone, is it possible? may it be a problem of electric resistance?
thnks
Nes4life
1,134CR
You could fit a philmurr 6116 mod and remove all 4 vec RAMs.
Otherwise, do you have many spare 2114s to swap them out? Are all 4 vec RAMs socketed?
Aspire
16CR
thanks nes4life.
News:
Well, i have made an adaptor for the 4 eproms to use only one 6116 (universal board made by me using an 7408 for generate an "and" for both -CS to make a -cs/-oe signal and using one -cs as a10 line)...and the same error, but i have news.
In test mode i have an error in 4 eprom (even using a new one, so is not a ram error).
In game mode I can ear the game, so is working, but i have a diagonal line.
Any ideas?
Aspire
16CR
News today.
MPU is fine, all running fine. tested separately from VSM all is fine (but blind obviusly).
At the end I have seen that rams 1 & 3 can not live together, if i put only ram 1 (Vector ram 1) it is tested good, but if i add the 3 ram, system reported ram 1 (Vector) as bad.
I will follow by looking the logical levels at this point in the CS line (common in 1 & 3 vector ram), all other lines are common with other ram ic´s.
