Asteroids - Rocks squashing and extra lines
RGP
Meeter & Greeter
2,039CR
Hey Guyyyyys we are ...... trying to get an Asteroids board working.....
Have a spare Asteroids board I would like to get working and having a bit of trouble.
First thing when powered on was that the high-score table wasn't showing at all and when you played through a game and got to game over, you'd get an extra life with PLAYER 1 GAME OVER still on the screen and then the game would reset after losing this life instead of jumping to high score.
Turning on test mode revealed a single low beep followed by a lower beep - a look in the manual helps here - it's a RAM fault being indicated - a 2114 @ E2 - the board had already had this socketed so a quick swap and the RAM fault is gone and the game now plays properly and the high score works and loops around attract mode properly.
Ok, now the more problematic one, the asteroids, ship, ships remaining etc all seem to generate extra lines from their origin point so you'll see a brighter dot and then a regular line coming into or going out of the object - and one in the centre of the screen. They do get cleared when you lose a life, start next level but then draw again - they move with the object (apart from the one in the center).
At first, I thought this was bright/contrast issues, have turned them down on the monitor but no change so it's not a monitor config issue.
I have narrowed in the X/Y gain as well and the cross-hatch (if accessed from cold start) shows the entire box as just inside the visible area of the monitor.
Secondary vector issue is that when the rocks go to the left side of the screen they become flattened against the edge rather than neatly drift off - now this might be because i've got the x-gain shrunk in so that you can see then entire render but looking at it in MAME it doesn't behave this way.
If I go into test mode from attract then I get a high pitched beep and the cross-hatch freaks out when trying to draw.
Not really knowing asteroids well, i'd say there's a vector generator issue or math issue or something like that but the cross-hatch will come up ok from cold power on but not from attract.
Odd.
Anyone seen this kind of issue before?
