Asteroids sound problem
minwah
238CR
trm said:
Have you definitely got a good battery in your test meter? You'll get screwy voltage measurements if it's going flat.
I put some spanking new Duracells in my meter and get the same (well, more or less) result. Odd.
4,058CR
minwah said:
guddler said:
Incidentally, having just re-read the first post, I'm now doubly convinced the wobbly vectors are either noise or grounding as per my post.
I just thought I should clarify that 'wobbly' may not have been a good description. Most of the vectors look absolutely fine. It is when the ship is at certain angles (ie not dead straight up/down/left/right), the lines that build the ship are not dead straight lines as you would expect. The lines are soft of jagged, almost like you get on a raster screen when drawing a diagonal line.
I tried to take a picture but I can't get it to come out well enough. However it looks a bit like this:
http://www.melchman.net/arcade/files/vector.jpg
I will stress again that the other vectors look fine. I'm not sure if it has to do with that the ship appears to have thicker or brighter lines than most other objects.
That's not right - it shouldn't look like that!
4,058CR
minwah said:
Anyway I did a sound recording which is worth a thousand words. You will hear that the sounds are not quite right. About half way through the recording, the nasty buzz starts happening, and gets worse. The machine had been on for 2 minutes when the buzz starts.
http://mamewah.mameworld.info/downloads/asteroids.mp3
WOW! You're not wrong. That's for sure not right!!
Is everything earthed that should be and everything grounded that should be also?
minwah
238CR
Well, as far as I can tell. All connectors are connected. The green earth wires from the loom are earthed to the power supply chassis. I got about 5 hours play time out of it before this odd noise started happening...nothing has been changed, except for todays addition of the jumper wires.
The only thing I can think of which isn't quite right is that took off one of the coin slot bulb holders as the bulb wasn't lit, and one of the contacts broke off. For now I've put insulation tape on the end of the cable until I can get a new bulb holder. I'm sure that wouldn't do any harm though!
Maybe I'll try unplugging the connectors and re-plugging them in case there's a bad connection somewhere...probably a long shot!
minwah2013-07-25 15:35:20
4,058CR
Something's definitely not right here.
I am somewhat guessing here as these kind of things are hard to diagnose without hands on time, but I wonder if the audio amp is overheating to the extent of breaking up. If you're able then it may be worth getting the AR board out and make sure the isolator on the sound amp is still doing it's job well and that any thermal paste is still good and not completely dried out / gone.
78CR
The sounds are generated individually by analog circuitry, unlike later boards with a POKEY. The explosions are generated by a polynomial random number generator, fed through some op-amp processing. You really need to put the board on a bench and a scope to diagnose where the problem lies.
Does the thrust sound ok? That also uses the polynomial, so if it's also bad, that's a good place to start.
Mark.
minwah
238CR
OK will do, I've got some thermal paste if needed. Are there two amps? They are the 5 pin components on the outside of the heatsink right? I'll check the solder joints on that board while I'm at it.
Thanks again.
minwah
238CR
Thanks for the info. I would say that all of the sounds are affected - they all sounds too 'thin' except possibly the explosion. If you able to listen to this you will probably hear that they are all not quite right:
I don't have a scope or probably the know how to diagnose problems on the board at this point (although I am interested in learning about it). It seems like a good idea to me to make sure the power supply and AR board are ok in the meantime though. Is there any point in replacing the big blue, capacitors on the AR board, and any other components? The capacitors all look ok to me, but I know some people like to replace them anyway.
minwah
238CR
DanP said:
From a quick listen everything BUT the explosion sounds fine to me?
They do sound pretty much ok...but they definitely sounded different (better) before. It's hard to explain but something has affected all of the sounds, but definitely most noticeable is the explosion.
P-Man
International man of mystery
1,273CR
what make/model is your meter? it could be faulty.
You could improve your graphics and eliminate hum by connecting the GND test point on the game pcb to the monitor frame and to the AR1 power supply test point (if it has it). If you still have a Hum, then you have other issues, possibly the AR1 sound amplifier, but also possibly the sound op-amp on the game pcb itself. Send the pcb/AR1 off to be fixed/verified, without looking at it on a scope its hard to verify correct operation in a cab with only basic tools.
minwah
238CR
It's an old Radio Shack one. It measures DC volts and mains AC fine. Maybe it's worth me buying a cheap one to verify.
I've got GND and 5V connected between AR and game board test points. I haven't tried GND to monitor frame but will do!
Sure I understand. pooman had the board fixed prior to me getting it but it's possible something's gone kaput since. Hope not...
minwah2013-07-25 15:34:46
minwah
238CR
Ok it's been a while but I've had another look at this now...
My multimeter died, so I bought a new one, it's an Amprobe AM-220 and seems pretty good. So my new voltage readings are as follows:
Pin 1/2/3 to 4/5 = 14.15 VDC
Pin 6 to 15 = 31.11 VAC }
Pin 7 to 15 = 26.55 VAC } should be 36 VAC
Pin 8 to 15 = 21 VAC }
Pin 9 to 15 = 13.43 VAC } should be 6.3 VAC
Pin 11 to 15 = 67.2 VAC }
Pin 13 to 15 = 44.4 VAC } should be 65 VAC
....so pretty much the same as I was getting with the old multimeter.
Some of the figures are quite a way off what they should be which worries me. Should I try to get another power brick? Or just not worry about it, since everything seems to be getting powered up ok, and the DC volts is (I believe) ok?
minwah
238CR
tb lilley said:
Not sure why you're measuring all the AC from pin 15.
I don't really know what I'm doing
That said I measured 6/7 and 8/9 with my old multimeter and they were not close to the expected - I will try those again with my new meter.
tb lilley said:
Pins 10&12= 60VAC
Pins 13&15=60VAC
Is pin 10 & 12 right? The schematic doesn't show a pin 10.
Also, what do you make of my 44.4VAC reading for pins 13 & 15? What tolerance is there?
tb lilley
5 Star
1,686CR
Ok - just measure 11&13 for 65VAC. Perhaps also meaure 10&14 if they're connected. See what you get (80VAC?).
Suggest you also remeasure 8&9 again. This must be close to 6.5VAC as it supplies the heater voltage to the monitor which appears to be functional. Also remeasure 6&7,
Ignore 10&12 and 13&15
Zektor
312CR
I had a similar issue with an asteroids cocktail. In the end I found the power brick transformer had a thin metal shield missing that wraps around the transformer body....that stopped the screen shimmer. If I remember correctly the AC power wires were tied in with the audio cables ...,worth checking.
minwah
238CR
Many thanks for clarifying - I will remeasure as suggested. I don't think 10 & 14 are connected from memory, but will check.
Thanks again!
minwah
238CR
My transformer does have the thin metal shield present.
Could you explain a bit more what to check with regard to audio cables? Thanks!
