G
Guests
Guest
[ukvac] Asteroids Tech
Hi Guys,
Curerently repairing an Asteroids and theres a problem thats been
bugging me...Although its mostly playing ok
I'm getting a spot in the middle of the monitor "most of the time",
although the rest of the display is fine....If I turn the
brightness/contrast up, I get a bright dot (duhh !! yer), If I turn
it right down, so that everything else dissapears, I get a very faint
glow still....
If I set the controls up for the game itself,as best as I can, I'm
getting a reasonable glow which is a bit distracting and about the
size of a small asteroid.
Now there is a bit of a spot burn on the monitor (no great shakes)
and I thought initially that it was down to this eg.. the phosphur
being a bit damaged or something.... BUT When I go to "High Score
Name Entry" , the spot moves to the bottom left of the 1st A letter.
I've tried 2 Deflection Boards, both the same problem, as I thought
initially that it might be a Z blanking issue.
Is this a common fault, or a "Standard feature" of this game ?
Alternatively I'm "guessing" that there could be some kind of fault
with the vector generator (I'm getting the other common fault of
asteroids sometime explode with a line problem which I plan to repair
soon).
Hope someone can suggest a remedy for this...This is the first vector
game that I've ever worked on, so I'm a bit unfamiliar with them..
Thanks, Regards, Colin
Hi Guys,
glow still....
soon).
