Asteroids tube fail ---- WHY ????
RGP
Meeter & Greeter
2,039CR
When you fire up do you see glow at the back of the tube on the neck? The heater voltage is fed separately from the brick.
No shorts just means it could be open circuit - measure the resistance across the relevant pins on the neck.
Mitchell Gant
888CR
There was a good heater glow, filament measured about 3 ohms.
No other shorts between any of the CRT pins to each other(well on pair read continuity, but was same on a working CRT) , or to the heater pins.
Anode voltage was a healthy 12kV.
So we're curious how it's failed quickly if it's got heaters, EHT and no shorts between cathode/grid/focus pins. No glow or spot at any point on the phosphor, in semi light conditions.
What failure modes do B/W CRT's have?
andrewsm
485CR
Unless the tube has lost its vacuum ie the neck has been knocked and cracked, its unlikely.It suggests that its a video fault or an anode fault stopping the beam. Check the focus circuit and cathode circuits.
Just a thought as tubes are quite tough and would have to be very low emissions to actually stop completely.
Sorry just seen that another tube works ok. So maybe vacuum is away or theres an internal short between electrodes.
andrewsm2016-09-04 00:09:43
PaulSwan
ZZZ
1,118CR
Over time the heater emission fades (CRT's do have a finite number of operating hours). If you know someone that has one, borrow a CRT rejuvenator and test/rejuve it.
If it were loss of vacuum you'd likely see and hear arcing.
Paul.
andrewsm
485CR
If the emission was low, then you would get a poorly focused and dim display. Was the picture bright and sharp before? Heaters wouldnt burn out that quick with no vacuum. They are not like light bulb filaments.
obcd
3,830CR
What if the screen grid no longer connects to it's matching tube pin. This would give the same effect as having the screen adjustment turned down completely. No idea how those things are welded together inside the tube, but can't such a junction come loose due to vibration or shocks?
