Asteroids vector RAM replacement - Interest check
chadsarcade
Lord of Vectors (tm)
443CR
philmurr said:
I'll tidy up the board design and get them ordered...probably around 3-4 weeks for delivery
I think you may be able to make one side of the holes for the skinny/fat 6116s common, then if I'm using a skinny I can shave off the unused holes making the whole thing no bigger than the socket it plugs in to...
philmurr
48 (100%)
2,378CR
I could common the left hand pins, but it will still be fitting into a 15.24mm wide socket on the Asteroids board. So you'd be able to shave the far left pins off and it will still be the same size as the socket.
Or do you have other plans for it...?
Mitchell Gant
888CR
Ah, just seen this. Better stick me down for a few please Phil, say 5.
I did a 6116 conversion myself like that back in the '90's when I got fed up of changing 2114's that always seemed to be failing. I think I sold that PCB to Purity, wonder if he still has it. It was a bit of a hack compared to your adapter!
All my boards are socketed with 2148 RAM's now and they're much more reliable than the 2114's, but won't harm to have a few of your conversion boards for future use. Desoldering 4x 18 pin IC's and socketing is a pain.
Shame it can't be used on Asteroids Deluxe, but there's no spare 24 pin IC position, as it's used by extra vector ROM.
Purity
The Oracle
17 (100%)
2,999CR
Probably not Neil. It was when I was more naive about these things and the boards were handed over to P-man. I think I gave him 6 boards and got 2 back, and one was a Dlx. Don't think the 2 I got back had any kind of 2114 mod but I'll have a look at them
philmurr
48 (100%)
2,378CR
The boards have been ordered and should be here in a couple of weeks or so. They'll be here in time for Steve's meet, so anyone going there can save on the postage.
I've ordered a few extras so there are some left over if anyone else wants any.
Macro
2,016CR
nice
philmurr
48 (100%)
2,378CR
Thanks to Phill Nes4life for assembling and testing the board
They're now available, came in at nigh on £1.50 each so that's what I'll charge for them.
Postage regardless of how many you buy will be £2 signed for. or £1 not signed for. I can bring them along to Steve's meet to avoid postage costs if you'll be there.
I'll do a proper for sale thread now.
Nes4life
1,134CR
Instead of using L3 and R4 I've decided to solder both connections to M5. Only one chip involved then and you could easily tidy it up further. Could even design V2 of the mod with this location in mind.
Just sold this Asteroids PCB complete with the mod so it seems people are generally happy with it as a solution (I am anyway). I was very careful to make it 100% reversible and very easy to do so (all 2114s were socketed).
T7klpHx.jpg1
Nes4life2017-07-27 22:49:03
chadsarcade
443CR
Finally got around to using one of these boards. I opted for a skinny 6116 and shaved off a set of holes to keep the PCB within the same footprint as the original 24 pin socket.
I went with M5 for the connections as well, one is to a nearby via which makes it a bit easier.
Still have some odd resets and glitches with this board, I think I'll carry out the single ROM mod next.
philmurr
48 (100%)
2,378CR
I think I got one of my plug in single ROM board working for Asteroids which means you don’t need to hack the board. PM me if you want one me to send you one.
